Need Help, Lights, I must be dummer than most
   / Need Help, Lights, I must be dummer than most #101
Well if your switches are rated correctly then you shouldn't have a problem at all.
If you do I would suspect that it will be because of a switch overheating but that should be pretty obvious if it does as things might get warm at the switch.
If it turns out that you do need a relay I will be more than happy to supply a wiring diagram for your needs.
   / Need Help, Lights, I must be dummer than most #103
Those conectors are great I use them for my inverter and cables also. For the lights I would say that the 50A are way over kill, not that there is anything wrong with that but you can get a two conducter trailer conector with 14g wire which work great and are only two bucks at AutoZone.
   / Need Help, Lights, I must be dummer than most #104
Did you ever get this figured out? If not, I have some questions for you. I think I know what's missing if I'm understanding this correctly.
Get What figured out?
   / Need Help, Lights, I must be dummer than most #106
Wiring up your relay and lights. I didn't read the entire thread so, sorry if I missed it.
Hi, Everything is installed and working fine. I wired everything without relays because I couldn't get them to work. If you check page ten of this thread I posted pics of my setup. A few pages more and FREDS posted his setup. I got around the relays by using a little bigger wire.
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2015 Ford Focus (A51694)
2015 Ford Focus...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
EZ-GO Electric Utility Cart (A55853)
EZ-GO Electric...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
