Need Help, Lights, I must be dummer than most
   / Need Help, Lights, I must be dummer than most #101
Well if your switches are rated correctly then you shouldn't have a problem at all.
If you do I would suspect that it will be because of a switch overheating but that should be pretty obvious if it does as things might get warm at the switch.
If it turns out that you do need a relay I will be more than happy to supply a wiring diagram for your needs.
   / Need Help, Lights, I must be dummer than most #103
Those conectors are great I use them for my inverter and cables also. For the lights I would say that the 50A are way over kill, not that there is anything wrong with that but you can get a two conducter trailer conector with 14g wire which work great and are only two bucks at AutoZone.
   / Need Help, Lights, I must be dummer than most #104
Did you ever get this figured out? If not, I have some questions for you. I think I know what's missing if I'm understanding this correctly.
Get What figured out?
   / Need Help, Lights, I must be dummer than most #106
Wiring up your relay and lights. I didn't read the entire thread so, sorry if I missed it.
Hi, Everything is installed and working fine. I wired everything without relays because I couldn't get them to work. If you check page ten of this thread I posted pics of my setup. A few pages more and FREDS posted his setup. I got around the relays by using a little bigger wire.
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2022 Chevrolet...
