I hunted down 4 lights at two Autozones. Apparently they only stock two at a time called tractor lights, which are the ones with the trapezoid beam pattern. Picked up some wire and plastic flex conduit. Looked at some switches at the local Carquest and found the same thing cheaper at the local hardware store. It's a toggle switch with a rubber boot labeled "marine" and I was told that all the grapepickers without cabs use that kind. Picked up two bolts for the ROPS too, to mount my angle with and 4 rubber grommets to use as isolaters for the lights. I may get to messing around with it today... in amongst disassembling one wall of kennel runs for my remodeling project, cutting 2x4s and drywall, picking up a new printer because my color one won't feed anymore and I need to print some stuff in color.... just the usual stuff when you finally have a nice day and want to work on an outside project (the lights -- no garage).  /forums/images/graemlins/grin.gif
Question: Do you do all the wiring and then slip the conduit over it and what do you do where the wire exits the conduit? Do you cut the conduit, start a new piece, push them close together and wrap the joint with tape? It seems like just letting the wire come out the conduit seam would cut into it a bit...
Also, if I mount the switches in the plastic dash do the need grounded? How would I do this with just the two wire terminals? Thanks and don't worry. Pics to follow when I get it done and operational. /forums/images/graemlins/smile.gif
