Need Help lighting for new garage
   / Need Help lighting for new garage #11
Is this a "garage" or a "shop" garage? I have a 28x32 with 10' ceiling and just used six keyless sockets (about $1 each) with screw-in compact fluorescent bulbs. This is plenty of light for normal work like checking/changing oil, lawnmower blades, etc. I'll use dedicated work lighting if I'm doing close fit-n-finish with a router or something small on the drill press. And no matter how well you light the ceiling, you still can't see the underside of the truck to work there :)
-rus-
Ditto. I did similar. Surface mount boxes and plastic bulb sockets. 75W equivalent CF bulbs. I didn't worry about making a symmetric grid layout. Put one right over the work bench and one in a corner where my tool cabinets are.
Careful you don't have shelving shading your workbench from the light above.
Dave.
   / Need Help lighting for new garage #12
the 4 footers are a lot cheaper, easier to replace, easier to find, and easier to transport.
(T8 not T12)
Yeah, 8 foot is better if you have a warehouse to light, for a garage the arguments fall apart.
Hey everybody thanks so much for all the suggestions I was checking online and found this
Commercial Electric 4 Ft. Shop Light with Lamp Grid and Pull Chain Switch
$22.68/EA
at Home Depot pretty good rating what do you all think?
   / Need Help lighting for new garage #14
$22.68/EA
I think you can get a simpler one for about 1/2 that price. I seem to remember about 11-12 bucks or so last time I looked, not too long ago.
   / Need Help lighting for new garage #15
Everyone I know that started off with 8' fixtures have gone to 4' because of the cost of the bulbs...
where did you see these for $11-$12? electronic or metallic ballast?
   / Need Help lighting for new garage #17
This is what I suspected. While I know HD/ Lowe's carries the 8' bulbs, I can't recall the last time I actually saw an 8' fixture. Whereas the 4' fixtures are everywhere.
   / Need Help lighting for new garage #18
H.D. ... I'll have to check. I've ever been concerned with ballast type, but haven't had any problems so far (7 years) with whichever I got.
   / Need Help lighting for new garage #19
As mentioned put your lights on 2 switches. In my garage I used 2 tube 4' fixtures with electronic ballasts and T8 tubes. Make sure the box says for cold start operation. Some say for use in 60 degree or higher temps. I bought mine at Walmart since they were cheaper at the time than Home Depot or Lowes.
   / Need Help lighting for new garage #20
8' HO's are a bit more expensive than the cheap 4 foot fixtures, however, lamps last much longer, light output from a pair of 8' lamps is more than double that of 4-4' lamps. Ballasts are longer lived. When maintence/replacement is calculated out over a period of years cost is the same or slightly less.
I recently finished my new home. I have two garage stalls (separate areas): one big two-car stall (29' x 30') and one single-car stall (26' x 12').
I bought the 8' HO fixtures and bulbs at Home Depot. They were a little more expensive, but they are NICE! I can't confirm their lifespan because I have only had them operational for 1 1/2 years, but I can ensure you that when you fip the switch, they turn on NOW! They are BRIGHT too, which is the way I like my shop/garage.
In the big stall, I have six 8' double fixtures and in the smaller stall I have two 8' double fixtures. All eight fixtures are on one 20 amp circuit, but the stalls are independently switched.
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Post Hole Digger Auger (A50774)
Post Hole Digger...
Massey Ferguson 383 (A50120)
Massey Ferguson...
Pallet Fees (A50775)
Satoh S-650G Tractor (NOT RUNNING) (A50774)
Satoh S-650G...
4' X 6' Steel Table (A50121)
4' X 6' Steel...
