Need help ID'ing a tractor
   / Need help ID'ing a tractor #1
double hunter
Ford 1715
Just bought a Ford industrial tractor and need help with identification, stickers have been pulled off hood, under the hood it has id plate that sez it is a model CU312K, called local Ford dealer and they could not ID from that number, I think they just didn't want to take the time to help me, it has a Ford 340 loader on it, I think it may be a 3400 just looking a pictures, I need to change the Hydraulic oil, can any one tell me if this has a external filter and internal screen, any help appreciated, will get a manual soon as I find what I have, thanks In advance.
   / Need help ID'ing a tractor #2
the number to id it or on the belhousing right behind where the starter bolts on
Is there supposed to be a tag or just numbers in the metal, I don't see anything in that area, but will check again tomorrow.
Finally got a chance to check this and all I see are same cu number, I'm looking right on top of the bell crank flange directly begind the starter.
   / Need help ID'ing a tractor #6
Yes, it is a 3400. If you can post the serial number the year of assembly can be decoded as well. That number is just below your model number and will be in the form of *Cnnnnnn*.
Thanks for the info,
2020 Bobcat T595 Compact Track Loader Skid Steer (A51691)
2020 Bobcat T595...
2017 Case SV185 Compact Wheel Loader Skid Steer (A51691)
2017 Case SV185...
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2004 Kubota L4630 (A50123)
2004 Kubota L4630...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
