Need help ID'ing a tractor
   / Need help ID'ing a tractor #1
double hunter
Ford 1715
Just bought a Ford industrial tractor and need help with identification, stickers have been pulled off hood, under the hood it has id plate that sez it is a model CU312K, called local Ford dealer and they could not ID from that number, I think they just didn't want to take the time to help me, it has a Ford 340 loader on it, I think it may be a 3400 just looking a pictures, I need to change the Hydraulic oil, can any one tell me if this has a external filter and internal screen, any help appreciated, will get a manual soon as I find what I have, thanks In advance.
   / Need help ID'ing a tractor #2
the number to id it or on the belhousing right behind where the starter bolts on
Is there supposed to be a tag or just numbers in the metal, I don't see anything in that area, but will check again tomorrow.
Finally got a chance to check this and all I see are same cu number, I'm looking right on top of the bell crank flange directly begind the starter.
   / Need help ID'ing a tractor #6
Yes, it is a 3400. If you can post the serial number the year of assembly can be decoded as well. That number is just below your model number and will be in the form of *Cnnnnnn*.
Thanks for the info,
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2025 CFG Industrial M-DRG (A50123)
2025 CFG...
Metal Peacock Lawn Art (A51694)
Metal Peacock Lawn...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
Lift Gate (A52377)
Lift Gate (A52377)
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
