Rotary Cutter Need help Identifying Old Shredder
/ Need help Identifying Old Shredder #1
lowe210
Help!!! I need some help in identifying what old shredder / brushhog I inherited from my Grandmothers farm. I can't find any ID numbers on it. It does have a gearbox with WARNER, AUBURN, IND on it and some other numbers on the PTO shaft. It has a 6 ft deck, and no 3-point attachment.
/ Need help Identifying Old Shredder #2
Can't help with the ID, but it looks well made.
A long time ago, I had a 5 ft, made like that, got it at an auction, don't know what brand it was.
/ Need help Identifying Old Shredder #3
Some early Bush Hog competitors were ground powered. The rubber tires provided power to the blades through a gearbox. They had to be very heavy for traction. When Bush Hog's patents expired, shredders became almost universally Three Point Hitch mounted and PTO powered.
Yours looks like a towed, as opposed to mounted, design; so no lift capability.
/ Need help Identifying Old Shredder #4
Why are you worried about IDing it? You should be able to replace any busted parts with commodity off the shelf stuff. Gearbox, PTO shaft & blades are likely to be standard parts. If not, standard parts could be easily retrofit in as needed.
/ Need help Identifying Old Shredder #5
If I was a betting man, I'd say a Massey Ferguson. The gearbox style is different than the older ones, but still looks like a Massey Ferguson setup to me.
/ Need help Identifying Old Shredder #6
If I was a betting man, I'd say this old thread is a waste of time.
The OP has not been around for a while:
KUBOTA L3901D TRACTOR (A64280)
KUBOTA L3901D...
2022 CATERPILLAR 259D3 SKID STEER (A64279)
2022 CATERPILLAR...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
2011 KUBOTA KX91-3 SERIES 2 EXCAVATOR (A64279)
2011 KUBOTA KX91-3...
2022 EZ-GO ELITE...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
