Need help identifying broken Bush Hog mower
   / Need help identifying broken Bush Hog mower
spindle was good, checked it on lathe and it was straight. Have a co-worker making a housing from some 2 1/2" stock, going to change it to ball bearings like the newer ones use. Tried to buy a housing but only available as an assembly which would cost about a grand canadian
   / Need help identifying broken Bush Hog mower #12
Picked up an old Bush Hog finish mower, it is a 5' mower and appears to be fairly old. Needs the usual bearings, blades and a belt, but it also has a broken spindle housing. Need to identify the model so I can try to purchase a housing or come up with a way to fix the broken one which appears to have already been welded once
Looks like my Bushhog TM-5 Serial # 1103003 it is obsolete. It looks like I can buy complete spindles for about 52 a piece.
   / Need help identifying broken Bush Hog mower #13
I downloaded manual from Messicks
The pictures are from my Bushhog TM-5 it needs total rebuild
   / Need help identifying broken Bush Hog mower #14
I look to AgriSupply for parts replacement for my old equipment, you might give them a try. I also have a 1960s disc harrow by John Deere with wooden bearings, I use AgriSupply to replace parts the bearings are replaced by steel bearings
   / Need help identifying broken Bush Hog mower #15
That looks like the one I have with a broken spindle.
   / Need help identifying broken Bush Hog mower #16
Same exact one I have a TM5 and when the bearing went it destroyed the aluminum housing. At that time Messicks had a used one but they wanted $300 for it because they quit making them. Good luck trying to find one. I only paid $300 for the whole thing wasn't paying $300 for one spindle.
   / Need help identifying broken Bush Hog mower #17
Dont know if this will help , but I have had different mowers over the years and a some of the housings were trailer wheel hubs where the lugs were bolted to the deck and spindle spun in it .
You know you just burst my bubble! I built an 8 foot bush hog back in the early 90's, had custom spindles made in the machine shop I worked at, and used 5 lug trailer hubs as bearings holders! I thought I had come up with something special!!
David from ja
INGERSOLL RAND  G40 GENERATOR (A58216)
INGERSOLL RAND...
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A58018)
2007 FREIGHTLINER...
pressure washer, and trailer (A56859)
pressure washer...
(2) HOMELITE BLOWERS (A58374)
(2) HOMELITE...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
