Need help identifying broken Bush Hog mower
   / Need help identifying broken Bush Hog mower #1
denm74
Nova Scotia
Kubota B2620, G1700
Picked up an old Bush Hog finish mower, it is a 5' mower and appears to be fairly old. Needs the usual bearings, blades and a belt, but it also has a broken spindle housing. Need to identify the model so I can try to purchase a housing or come up with a way to fix the broken one which appears to have already been welded once
   / Need help identifying broken Bush Hog mower #2
Dont know if this will help , but I have had different mowers over the years and a some of the housings were trailer wheel hubs where the lugs were bolted to the deck and spindle spun in it .
   / Need help identifying broken Bush Hog mower #3
I think Bush Hog has lots of manuals on line. My only suggestion is to head over to the Bush Hog website and start looking through those manuals. You might get lucky and eventually find one.
The only other thing I can think of is to email Bush Hog some pics and ask for help identifying the model and part number you need. Most of those companies have some old timers working for them that have been there for years. There is a chance they could help.
Is there not an ID plate anywhere on the mower?
Tried emailing Bush Hog but still have not gotten a reply from them
I can still buy a housing assembly but pretty much gonna eat a grand!, mower just not worth it. Decided to build a new housing out of steel
   / Need help identifying broken Bush Hog mower #5
Are you sure that's a Bush Hog brand mower?
Spindles look just like ones on my Pittsburg 220 mower. They were impossible to find.
Gear box says bush hog and when I do a parts search on bush hog tm5 it looks exactly the same
When I get the spindle housing built I will post a picture of it. I did get the 2 good spindles rebuilt, new belt, new blades are ordered, wire wheeled the body and painted it, a bit different than it was a week ago
don't think it would work, a little short. like the price though :thumbsup:
   / Need help identifying broken Bush Hog mower #10
The spindle shown with the bent shaft and broken housing splits in half along the length to get the bearings and shaft out, That's what the bolt just under the pulley is for, holding the two halts together. I rebuilt 3 of these on my mower. They take standard 1" trailer bearings, bought them from Tractor Supply.
When I searched for a replacement I could not find one except through the dealer. It was about $100. Did you buy a new spindle?
Nice job on cleaning up the mower, looks good.
2017 Ford F-350 (A56858)
2017 Ford F-350...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A55851)
2015 Toro Multi...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
GEHL RT175 GEN 3 SKID STEER (A52707)
GEHL RT175 GEN 3...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
