Need Help ID this Nut & Bolt
/ Need Help ID this Nut & Bolt #1
W8BYA
Ossian, Indiana
NH Boomer 40
Howdy group. I came across a very large number of these new nuts & bolts but am not familiar with the stamping on the head. I suspect they are metric as the bolt measures exactly 3 cm in length and a standard 5/16-18 coarse will almost thread on but does not. I read it as 3F on one side then 8.8 across from that. Looks like a heavy Chromate coating for corrosion resistance.
/ Need Help ID this Nut & Bolt #2
It's an M8x1.25 30 mm long bolt. The 8.8 is the grade for metric bolts.
In the land of metric, we don't even bother to mention the pitch (1.25 in this case), only if we actually want a fine thread or something. So we would just call it M8x30 mm bolt.
/ Need Help ID this Nut & Bolt #3
Ok, I understand the 8.8 grade part, but how did you know M8x30mm? From the markings?
/ Need Help ID this Nut & Bolt #4
The thread diameter and pitch of the M8 and the 5/16 bolts or nuts are very close to each other. It will actually work if you force it there, but you may end up with a slight mix between a 5/16 and a M8 thread.
As far as the length, the provided metioned in the first post.
Hey that's great, thank you. A boat load of grade-5 bolts I can live with. Am I close in assuming the 3F marking is for 3 cm? But what about the F marking?
/ Need Help ID this Nut & Bolt #6
That would be a manufacturers marking/ID, so not really important.
3F is Fontana Luigi
Darn it ! I was hoping these bolts were Ferrari or maybe Lamborghini :)
Thank you for letting me know. Fascinating all that information can be easily put on the head of a bolt.
/ Need Help ID this Nut & Bolt #9
There are times when English and metric overlap. It can be dangerous.
There are lots of ways to size a bolt. At my Lowes or ACE hardware stores have these and you can buy them as well.
Keep something close by. It will save you time and money the first time you force a bolt only to find out it won't hold and the threads are stripped.
I have a set of these in my tool bag.
Both of these are great ideas. Normally I would go to my local fastenal (which is just 5 min away) but they have closed there main door, open only for P/U's etc. What a shame as they are a wonderful source.
/ Need Help ID this Nut & Bolt #11
Thanks for that post and picture. I had no idea on the tensile strength of the metric 8.8 being so much lower than a grade 8 SAE bolt. Seems the metric is about a grade 3 in SAE. Need a grade 10.9 metric to equal a SAE grade 8.
/ Need Help ID this Nut & Bolt #12
Keep in mind that according to that chart the metric 8.8 has way less strength than a SAE grade 5. More like a grade 3.
Thanks. I ended up with a lifetime supply (plus some) so they are what they are. I am glad they are of good quality. Next I need to find a new home for about 500 of them.
/ Need Help ID this Nut & Bolt #15
Interesting... when i get my hands on imperial fasteners, i measure them up in mm, divide that by 25.4 and then try to find how that translates to a fractional dimension...
Then i set my caliper to 25.4mm and count the threads per inch.
When i have metric bolts of a non standard pitch, i count ten windings and measure the mm. Dividing the measurent by 10 andi know the pitch.
To be honest, i dont save imperial bolts: I dont know of any piece of equipment imported to Europe, that uses them so its pointless to save them. AFAIK since the 60s all English produce (Ford, Perkins, IHC) adopted Metric.
Dodge Charger (A56859)
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
2014 Jeep Grand Cherokee 4X4 SUV (A61574)
2014 Jeep Grand...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
1999 John Deere 7810 (A60462)
1999 John Deere...
