NEED HELP guys.JD 175 Will not spark!!!!!!!!!
   / NEED HELP guys.JD 175 Will not spark!!!!!!!!! #11
Take a jumper wire and clip it on the positive side of the ignition coil and put the other end on the positive side of the battery. Crank engine and if it starts, there is a break in the wire from the ignition switch to the coil. If it doesn't then you either have a bad coil or the points are burned out. Report back after you do this and we can go from there. What is the brand of engine and if necessary, I can send you to the correct engine group for further assistance.
Im not sure which one is the ignition coil, If you are talking about the coil/mangeto that supplies spark there is no positive termilnal to that just ground and the ground at the coil has coniunity.
   / NEED HELP guys.JD 175 Will not spark!!!!!!!!! #13
In almost every case where I have had bad ignition on a small engine, it has been the points or condenser. You may have to pull the flywheel to get to them. They would have been the first things I would have replaced.
Andy
   / NEED HELP guys.JD 175 Will not spark!!!!!!!!! #14
The positive terminal would be the wire going from the coil/magneto to the condenser.
   / NEED HELP guys.JD 175 Will not spark!!!!!!!!! #15
The Kawasaki will have electronic ignition, do NOT cross 12 volts over on it or you will Fry it if not already bad. Sorry but that is all I know about it. Get a small engine repair manual that covers it , is my recommendation.
Ok i called around to some JD dealers and we have come up with either the coil or most likely the Ignition trigger there both 50 bucks each Im goona replace the trigger this week and I will post back.Thanks for the help.
   / NEED HELP guys.JD 175 Will not spark!!!!!!!!! #17
Polish the iron part of the coil that sets near the flywheel and the iron inserts in the edge of the flywheel that pass next to the coil with some emery cloth or sand paper before you buy any parts. One of my hands fixed his lawnmower that way today. I haven't bought a lawnmower in years, I pick 'em up off of trash piles and fix 'em and this is a very common reason for no spark.
Well, I got it running, It was the ign trigger, 55 bucks from JD.
Thanks again I wish I could figure out how to post a pic on here.
I figured it out check out the tractor.I have ~260 bucks in it.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52128)
Kubota 24in Quick...
2014 Chevrolet Express Cargo Van (A50323)
2014 Chevrolet...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
Payment Instructions (A47384)
Payment...
