Need Help - grounding rod install
/ Need Help - grounding rod install
Trust me. I tried. Alway need a new tool. Wife said I needed the excercise more
/ Need Help - grounding rod install #24
I think I would have went back with PVC piping for the well. My Dad had one put down 40+ years ago and it is still pumping from that 2" line. Even the pump point is homemade by the well guy. Just a 5 foot section of pipe that he took a hacksaw and sawed about 1/3 thru from each side alternating the holes. He then poured crushed stone down the drilled shaft to settle around the "pump point". It would fill a 150 gallon tank in 3 minutes which is all the capacity the well pump had.
/ Need Help - grounding rod install #25
James, that video was interesting about the ground rods and depth.
/ Need Help - grounding rod install #26
Yes it was enlightening. If anyone had asked me, putting 120 volts direct to a 10 foot ground or even a 50 foot ground rod, would have popped a break, but looks like all it did even at 50 foot was warm up some earthworms.
/ Need Help - grounding rod install #27
Some interesting tests on the effectivness of ground rods at various depths etc.
https://www.youtube.com/watch?v=Yg6G5VUSsWA
Interesting never seen a comprehensive test like that with results and how/why/what was done.
I put that into my YOUTUBE channel for future ref... People at work were going crazy over kill on grounding wire size just Friday and I knew better than what they were doing but the new guy can't raise waves...
Mark
2014 FREIGHTLINER CASCADIA 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2014 FREIGHTLINER...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A64553)
2023 John Deere...
Genie GS-3232 32ft Electric Scissor Lift (A64553)
Genie GS-3232 32ft...
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A67147)
2005 MACK CXN613...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
