Tires Need help finding front tire
/ Need help finding front tire #1
mjack
arkansas
Farm Pro 2420
Can anyone tell me where I can order a 4.00-16 front tire for my farm pro tractor I cant find one no where.
Thanks
/ Need help finding front tire #2
Would a 5.5/16 actually fit the rim? If so, that is readily available for $52. A 4.0 tire sounds mighty narrow. That is the same width as most wheelbarrow tires.
Look at your owners manual to see if there are multiple sizes that will fit the rim. Going to a narrower rim with a 5.5 tire might work. However, there is no way you will ever make a 4.0 tire work on a much wider 5.5 rim.
The 4.0 tire might have been a money saving measure by the factory if it was the original tire.
/ Need help finding front tire #3
Where did you buy your tractor from? I think your dealer would be the best bet to find that size. Miller Tire, Firestone, Titan and Michelin do not carry that size from my quick looking at their websites. Other then your dealer I would go to your local tire store and ask them if they can find one.
Ok thanks for the info I tried my dealer and they dont sell them either.
/ Need help finding front tire #5
Thanks
Hey MJack,
You might try Jinmaparts.com,,, Tommy at AffordableTractors.com,, Chip at Artrac.com,, or FarmPro Tractor at Homier.com,, or Ronald at Ranchhand supply
Hope this helps,
Joe:cool:
/ Need help finding front tire #6
Hey joe,whata know?,,,been over here bothering every body for a while now,,couldn't get on your site,tried many times,,,,if you could help me out,I'd come over and bother you all,,,,[what,,you mean the lines busy?,,now wait thats what the last site said,,,],,,yeah,,one of those places is guaranteed to be able to get the man a front tire,,bet northern tool could as well,thingy
/ Need help finding front tire #7
mjack said:
Can anyone tell me where I can order a 4.00-16 front tire for my farm pro tractor I cant find one no where. Thanks
There just aren't too many of the little 2wd Jinmas around. I think Homier has probably sold the most. The 20hp 2wd is here: Farm Pro 2010 Tractor Series, but I dont' see tires in their parts list. I'd contact them anyway, on the off chance they have a parts tractor from which they can cannabilize one
Otherwise, about the smallest 16" front tractor tire you're going to find - that has decent sidewalls anyway - may be the 5.50x16. Being a little wider, it might make steering a little harder - uless you got the power steering version. Might have to adjust the front turn stops too, which decreases your turn radius marginally. It's only 4wd tractors that you have to worry about mis-matched front/rear rolling radius.
//greg//
/ Need help finding front tire #8
The tire is listed in the link Greg provided. The part number is GB/T2979-1991. They also list the tube with the same part number. It's listed under "Directive Wheel" in the parts list.
Rodger
/ Need help finding front tire #9
Rodger
Good catch Rodger. I'd have never pegged a directive wheel as a tire. If anything, I might have guessed rim. But once I open the graphic, I see it represents rim-tube-tire.
Did you notice that the tire and tube share the same part number ?
//greg//
Hey thanks for all the help I have a call into them to see if I can get one. You guys are great keep up the good work.
/ Need help finding front tire #11
What is wrong with your original tire?
My front tire had a 1" slash/rupture in the sidewall. Could not find a (6.50x16?) replacement anywhere, even my tractor dealer. They offered to purchase one from China. I took it to many tire dealers including industrial/tractor dealers. All the tire dealers said the dire can't be repaired because injury was too large.
I purchased a sidewall boot from Miller Tire and fixed it myself. 20 hard hours later the tire is still holding up to extreme weight and works as good as new.
We'll see how the next couple hundred hours do,
/ Need help finding front tire #12
I've seen large gouges and tears that went from a couple inches of the bead to the tread area. A few were 'laced' up with heavy farming wire, and one had a pice of another tire BOLTED on using 1/4" hardware. I assume both types of repairs also used a boot, and or and old split innertube in the casing, as well as a new tube.
Soundguy
/ Need help finding front tire #13
I have a very thick piece of rubber in one of my front tires "covering" a tear in the sidewall. It slipped once and allowed the tube to be exposed. Since then I have over a hundred hours of pretty rough use and no problems. I just make sure the tires are aired up to operating pressure before heading out.
/ Need help finding front tire #14
Thanks
Is this a 4WD unit? May be cheaper to start looking for an alternate rim in a standard size. If 2WD, and it were mine, I would take/make some rims to fit, then get tire and your good to go.
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2020 INTERNATIONAL...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
1995 FORD F-SERIES S/A GRAIN TRUCK (A64278)
1995 FORD F-SERIES...
2007 MACK CTP (GRANITE) TRI AXLE DUMP TRUCK TRACTOR (A67147)
2007 MACK CTP...
