Need help finding a tooth bar for my bucket
   / Need help finding a tooth bar for my bucket #1
Bansil
State Of Franklin
1967 Ford 5000 w/FEL(sold), 1950 Farmall Super A for the wife to drive around (needs fixed) 2024 Kubota B2601 FEL & BH
When I had my Ford 5000, I made a tooth bar out of a 6x6x5/8 angle iron, I used a grinder and cut off wheel to make the teeth on both edges. It slipped over the bottom lip of the bucket, and straps around bucket held it on.
So I had teeth to the front and down under the bucket
I used it to back pull vines,scrub brush/trees etc. Basically I pulled up into the woods, dropped bucket on the ground and backed up pulling everything back with both cylinders compressed so no chance to bend them since they were not extended out.
Everything I'm finding only gives you forward teeth, to use them to back pull vines would leave my cylinders completely extended with bucket tilted all the way forward and I risk bending them.
Do I have to make another bar or do they sell one?
Thanks
   / Need help finding a tooth bar for my bucket #2
I made something that sounds like yours on my last tractor. It was fashioned after the commercially available Ratchet Rake. There is an assortment of tooth bars with forward-facing teeth on the market.
   / Need help finding a tooth bar for my bucket #3
do you have a float function on your fel?
Is that 3/16" or 1/4"...or?
That's what I'm looking for! No need for forward teeth. If I have to i will l make one, my plasma table is only 36x48 so I will need to make two pieces and weld them together. This will be for a very specific project for reclaiming some land.
   / Need help finding a tooth bar for my bucket #6
float position should relieve pressure somewhat back dragging (unless you hit a big snag). i'd avoid down pressure, best of luck.
   / Need help finding a tooth bar for my bucket #7
Think it was 1/4". That tractor was sold about 4 years ago and the attachments went along with it. To hold it on, there were tabs you can see in the bucket, and there were chains around the back. The chains were tensioned with bolts (allthread) through the upper lip of the bucket.
That is about exactly how I made the last one, thanks for pictures
2025 AGT QK16R Mini-Excavator with Dozer Blade & Hydraulic Thumb (New/Unused) (A59225)
2025 AGT QK16R...
2007 Ford E350 (A55973)
2007 Ford E350...
2018 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A55973)
2018 Ford F-350...
Kubota B21 (A57148)
Kubota B21 (A57148)
2012 PETERBILT 388 WINCH TRUCKS (A58214)
2012 PETERBILT 388...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
