need help choosing: YM2000 or 1610
   / need help choosing: YM2000 or 1610 #11
I would say for stability, the YM2000. That is just seat of the pants experience, not scientific proof mind you. Of course if you get it from Tom, he can hook you up with ROPs for any of the models he sells.
located in Cleveland, AL (Blount County)
   / need help choosing: YM2000 or 1610 #13
You'er not that far up the road from me.
   / need help choosing: YM2000 or 1610 #14
For work on hills I would be sure to get a 4x4. I have a steep yard and after the last Hairy trip down the hill sliding on leaves and planning what to do if I did not stop before I reached a 2' drop next to the road I orded my 2020d. Heavy, 48'' wide, 4 wheel drive adds lots of control plus I can back up the hill (not possible with 2wd) I feel very safe on the tractror not one slip in 4wd. running across steep grades is not good with any thing other than a very wide machine.
I am a Locust Fork grad
. Go hornets.
   / need help choosing: YM2000 or 1610 #15
Guess we could just get all the Alabama folks in here!!!!!!
   / need help choosing: YM2000 or 1610 #16
Brent brings up an important issue. ROPS. ROPS can be put on most of these tractors now. If were worried about tipping over I would get a tractor with ROPS and wear my seat belt. This also would mean getting one large enough for my body. If you have alot of mowing you will want to run the widest mower so size of the tractor is very important. Wider is more stable.
   / need help choosing: YM2000 or 1610 #17
I have a 1602D, which is 4X4 and gear trans, and I concur with a lot of what the other guys are saying, you need to try it on first. I'm not that big of a guy, but climbing on and off is a bit of a pain, it's easy to get your feet tangled in the pedals. As to ability, mine has done everything I've needed, which is pretty much as you described. I also really like the 4X, since my property is hilly too, plus I have a FEL and the 4X makes it more comfortable to work with, especially backing out of a hole with weight in the bucket. My advice is the same as the other guys, find a good dealer and let them educate you a bit, then try some on for size till you find the right one...........
   / need help choosing: YM2000 or 1610 #18
I agree with the greatrandini. I would go for the 4WD and the Powershift transmission. I have a 3110D and like it a great deal. I also live a few miles north of you (Arab Alabama) and I know your town, which has about the same terrain as ours. I believe you would find an appreciation for the 4WD, Powershift and make sure you get a ROPS equipped tractor. I have dealt with Fredricks Equipment in Hartselle and they are good folks. Good luck.
   / need help choosing: YM2000 or 1610 #19
The 2000 IS a syncromesh, you don't have to stop to shift gears.
   / need help choosing: YM2000 or 1610 #20
I always vote 2 cylinders, longer life, less fuel more torque per hp.
The YM2000 transmission that is apart on my bench does not have syncro’s in it.
Buck
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
