Backhoe Need help choosing a backhoe
   / Need help choosing a backhoe #11
The BH90X is pretty capable; I like mine. The heavier your tractor the better.
Stumps of any size can be a fight. The effort seems out of proportion for what's actually achieved. Starting to believe my tree guy is right: "Grind 'em". Snatching out the smaller ones isn't bad.
Bob
I'll definately check out the PTO pump discussions.
I also, it would appear, need to see the BH90 in person. A friend has a Bradco 509, and it is significantly more a machine than the BH80. Embarrasingly so.
But a couple folks suggest the 90 is a better piece. The specs on the Bradco equipment is quite a bit better than the Woods as well. Granted, I know it's all a game of numbers, but there has got to be a little truth hiding as well.
In my case of the stumps, nope, there will be no grinding. It's removal or removal.
Then again, this all may come down to price too! ;)
   / Need help choosing a backhoe #13
SJ,
If your main goal is stump removal, you may want to closely look at bucket size.
I have been drooling for a BH80 for my TC 34, and in my research came across comments advocating use of 12" buckets for stump removal b/c it was much easier than the std 18" material bucket.
My dealer had a very slightly used NH 757, at a great price... but I like the permanent Woods subframe. So storage space is also big consideration for me.
Rich
   / Need help choosing a backhoe #14
I think Dave is right in that the 3pt hoes are not going to be as powerful as you expect. I have a 7-1/2' Nardi J-220 and my friend has a similar size Bradco. They seem to be pretty much equal in performance. Nevertheless, neither are like a dedicated TLB industrial strength hoe. Mine is PTO driven pump and his is plumbed to the tractor hydraulics. It all depends on what the psi and the size of the cylinders you have. I usually slow the tractor rpm down a bit since I don't need the fastest moves which is what more flow will give you.
One thing I would recommend is to be sure to get an 8 or 9 footer. Not just for added strength or digging depth, but for reach when trenching. I found even mine lacks the reach I wanted and I find myself constantly repositioning. My tractor is a 55hp Kama and could easily have handled a larger capacity hoe.
The other thing is that you'll need to figure out the best way to make it perform for you. Especially for stump digging. The suggestion of using a smaller bucket is a good one. You'll find it can dig more aggressively and get better penetration. If you really need to rip out roots and dig out rocks around the roots, maybe a backhoe ripper like this would be the solution. I could see that coming in handy when digging out tree stumps.
   / Need help choosing a backhoe #15
I have a Woods BH90x and am looking to get a ripper just like that for stump pulling. For 6-12 inch tree stumps I find that if I can break the lateral roots I can tip the stump out of the ground without really digging it out. If I had a ripper I could do that with very little disruption of the land compared to what happens when I perform these steps with a 18 inch bucket. I contacted Woods and they don't make or offer a ripper but they did send me the bucket dimension drawings so I can have one fabricated. BroTek can do it and I might go that route if I don't find a simple local solution. I'd love to do it as a project myself but don't really have sufficient metal working skills at this point (though embarassingly I do own all the necessary equipment:eek: )
   / Need help choosing a backhoe #16
I have drawings/plans for a backhoe ripper tooth under build-it yourself. They have been updated since I posted them cause I need them detailed enough to take to a welder and fabricate the ripper tooth. I dont have my backhoe right now (being painted) so there are few dimensions that are swags.
http://www.tractorbynet.com/forums/build-yourself/112103-backhoe-ripper-tooth-again.html
I plan on having this made sometime this winter, so once the ground thaws I can start playing. I have some stumps that are almost 26" that I want to remove. Ya Ya .. rent a stump grinder.
There was a previous post TBN about a home-made ripper tooth that gave me most of my info.
   / Need help choosing a backhoe #17
Thanks Wedge, I'll look up that thread. The Woods bucket mount drawings are precise enough that the only thing I really need is to figure out whether the ripper tooth itself should be fabricated or just to use a box blade ripper. It is not exactly a precision piece of equipment so I imagine someone with a plasma torch and grinder could make a ripper tooth in about half an hour.
   / Need help choosing a backhoe #18
Islandtractor.. I'm looking at getting some teeth off ebay, but I'm still trying to figure out what it really needed. I see that they have teeth and they have "shanks" Right now I'm under the assumption that you weld the shank onto the implement then mount a tooth over that. Correct?
   / Need help choosing a backhoe #19
I think the "teeth' you are looking at are probably the replaceable teeth for backhoe buckets etc. I don't know how necessary those are for a simple ripper tooth. The rippers used on box blades may not be deep enough (front to back) to be easily stabilized for the forces that a backhoe could put on them. I'd image that bending will be a problem unless they are sandwiched between two hefty plates.
The more I think about it I believe that a ripper tooth could just be cut out of a single piece of 1/2 inch steel and then have some sacrifical cutting pieces welded to either side of the business end. I don't really see a ripper as being something that gets used 8hrs a day and as it is mostly just in topsoil and tearing up wood roots, wear may not be such an important consideration. I posted a diagram of a ripper on your other thread but will repeat that here. I don't think this would be difficult at all to fabricate and could be close to trivial for a shop with a CAD system plasma cutter and any 220v welder. I'd think about 1/2 mild steel (??maybe more)would provide sufficient material strength for an 18 inch ripper for my Woods BH90x but that is just guess.
  • RipperToothDwg.pdf
   / Need help choosing a backhoe #20
I think with backhoes the specs tell an important story. I've used woods and kubota backhoes ranging from 6.5 ft to 9ft and just recently got a Bradco 511. There is just no comparison, and the difference is reflected in the digging force specs. Backhoe attachments on tractors will never match a TLB, but the Bradcos come pretty darn close, adn do match the power of some of the new smaller TLBs from Kubota and JD. I think a Bradco 509 or 511 would make you very happy.
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
WOODS 9021 BATWING MOWER (A57192)
WOODS 9021 BATWING...
2018 Ford Fusion (A56859)
2018 Ford Fusion...
10ft Enclosed Cargo Trailer (A55853)
10ft Enclosed...
2023 John Deere 332G Skid Steer (A53485)
2023 John Deere...
2015 Ford F-350 Knapheide Service Truck (A55852)
2015 Ford F-350...
