Need help ASAP please.
/ Need help ASAP please. #11
I got it figured out...somehow I confused the two lines reconnecting to the scv and I just swapped them and all is fine now.Thx for the replies and happy holidays.
Any more detail??
Did you mix up one of the lift hoses with a curl (angle) hose??
I dont see how just swapping the two curl (angle) hoses would make a difference in function. Other than when you push the stick left and the plow goes right and vice versa. But still shouldnt cause the issue you describe.
/ Need help ASAP please. #12
BTW: The plow cylinders may be single acting as individuals, but paired up with the plow angle they become a double acting system using the mechanical linkage connection between them.
So, one line from the loader valve goes to one of the plow cylinders and the other line goes to the other plow cylinder. When one cylinder is energized, it pushes the other cylinder closed as the plow angles and vice versa.
Any more detail??
I just swapped around the to curl /dump hoses at the scv and it works like it should now.I dunno why but I sure would like to know,but im glad its working.
/ Need help ASAP please. #14
Just for kicks, swap them back again and see if it works. I am thinking you didn't have one of the couplers seated properly.
/ Need help ASAP please. #15
whats a scv?
remember when hooking or unhooking hyd lines its engine off and cycle your loader handle a couple times in each direction to bleed off any residual pressure.
A little residual pressure pushing against a quick coupler can prevent it from seating properly.
/ Need help ASAP please. #16
whats a scv?
scv can be several things. Southern California Valve company….Sons of Confederate Veterans, etc, but in tractor/hydraulic parlance, it usually means selective control valve.
Swapped them back to how it was before..doing what it was doing yesterday it doesn't make sense to me.
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A61165)
2004 MCI D4500...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
Rotary SPOA9-200 Automotive Lift (A59230)
Rotary SPOA9-200...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
