Need help ASAP please.
/ Need help ASAP please. #1
diesel97
connecticut
jd 790
Got a snowstorm coming and trying to figure out why my snowplow is acting up.I recently rigged up a jeep snow plow onto my JD 790 tied into my dump /curl circuit.Problem is now when I tilt the plow using dump line for left turn on plow its fine ...but when I use curl to tilt plow to the right I can only move my control stick a tiny bit or else it wont move the plow to the right.Now I just hooked up my forklift attachment to the tractor and when I pull the lever toward me to curl up it works fine.but when I push away from me to dump I can only move the lever a tiny bit to dump ..maybe a half inch anything farther and it starts to curl up on me when its supposed to dump.Anyone have any ideas.Thank you.
/ Need help ASAP please. #2
Hardly an expert but I believe plow cylinders are single action and loader cylinders are double. In other words, loader cylinders will push AND pull as they have a hydraulic connection on either side of the piston (both ends of the cylinder). Plow cylinders only push, having a hydraulic connection at one end only. There's probably a way to make it work but I can't help with that.
Good luck!
/ Need help ASAP please. #3
can you send a photo of the plumbing, how did you hook the plow single acting cylinders to the bucket dump/curl circuit?? just on the way to the shop to finish hooking up and wiring the plow for the Jeep. we are getting a 1 1/2 feet to 2 feet on sunday/monday.. YESSS
/ Need help ASAP please. #4
some more background on how you have this plumbed would help but it sounds like you possibly have quick disconnects that are not snapped all the way together.
/ Need help ASAP please. #5
If your tractor is similar to most newer ones, when dumping, it has re-gen. Meaning that it applies pressure to both sides of the cylinder, and naturally it dumps because the the piston has a greater surface area on that side. It is done to speed things up. BUT....if you push the lever ALL the way to the right, should be non-regen. Slower for loader work, and more power, but is what you need for being hooked to two SA cylinders. Cause in regen, you are opening the valve to allow full pressure to both cylinders.
My guess would be that one side opens a tad sooner than the other, that is why it moves if you just crack the valve open, and would also guess that there is a slight differences in geometry between the two sides of the plow, allowing equal pressure to both cylinders still angle the plow one way.
This is the best I can do without more info.
Yes the plow cylinders are single...one hose hook up per cylinder.I basically just unplugged the 2 dump curl lines from my scv ports and ran 2 lines up from the plow into the 2 I unplugged from the scv.
/ Need help ASAP please. #7
your control valve for the curl/dump is more than likely a regeneration spool or an external valve, it takes fluid from the rod side of the cylinder and moves it to the base side of the cylinder to increase speed when curling the bucket back.You can not get regen on a single acting cylinder. if you reverse the hoses on the plow it will more than likely just change the problem to the other side, if it does then you are will need to change the hydraulic circuit for this . it may be in the spool or it could be a remotely installed valve for the regeneration circuit.. Jim BOOK 2, CHAPTER 17: Regeneration circuits | Other Technologies content from Hydraulics & Pneumatics
/ Need help ASAP please. #8
Shouldnt have to change anything. Just push the lever all the way and OUT of regen mode. Regen usually ISNT the only way the valve can work.
Diesel97, try what I suggested. Push the joystick all the way right. Its like the float function on the lift, the joystick has two positions when moving left. Most people are none the wiser.
no dice it didn't work..i have no clue.
I got it figured out...somehow I confused the two lines reconnecting to the scv and I just swapped them and all is fine now.Thx for the replies and happy holidays.
/ Need help ASAP please. #11
Any more detail??
Did you mix up one of the lift hoses with a curl (angle) hose??
I dont see how just swapping the two curl (angle) hoses would make a difference in function. Other than when you push the stick left and the plow goes right and vice versa. But still shouldnt cause the issue you describe.
/ Need help ASAP please. #12
BTW: The plow cylinders may be single acting as individuals, but paired up with the plow angle they become a double acting system using the mechanical linkage connection between them.
So, one line from the loader valve goes to one of the plow cylinders and the other line goes to the other plow cylinder. When one cylinder is energized, it pushes the other cylinder closed as the plow angles and vice versa.
Any more detail??
I just swapped around the to curl /dump hoses at the scv and it works like it should now.I dunno why but I sure would like to know,but im glad its working.
/ Need help ASAP please. #14
Just for kicks, swap them back again and see if it works. I am thinking you didn't have one of the couplers seated properly.
/ Need help ASAP please. #15
whats a scv?
remember when hooking or unhooking hyd lines its engine off and cycle your loader handle a couple times in each direction to bleed off any residual pressure.
A little residual pressure pushing against a quick coupler can prevent it from seating properly.
/ Need help ASAP please. #16
whats a scv?
scv can be several things. Southern California Valve company….Sons of Confederate Veterans, etc, but in tractor/hydraulic parlance, it usually means selective control valve.
Swapped them back to how it was before..doing what it was doing yesterday it doesn't make sense to me.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
New Holland 273 Square Baler (A66408)
New Holland 273...
2021 International HX620 Quint Dump (A62613)
2021 International...
(16) Kinze 60 Cell Bean Plates (A65640)
(16) Kinze 60 Cell...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
