need help adding third hydraulic link
/ need help adding third hydraulic link #1
wendelin
Oakley KS
JD 185
I have a fx32d with a koyker 155 loader. I am wanting to add a third valve for the back of the tractor. If anyone could give me any pointers I would appreciate.
I also have a couple of problems wth the tractor.
I have oil on the inside of the front left rim. How would I fix this?
I also have oil comming form the back underside of the tractor. Not sure if it is coming out of the pto. Have not had time to look it over very well.
Any help you all can give would be great.
thanks a millon
wendelin
/ need help adding third hydraulic link #2
To add a 3rd valve run the OUT hose from your loader valve to the IN of the new valve & OUT of new valve to place where the loader OUT hose was attached. You probably need some seals. Email me with what you need.
/ need help adding third hydraulic link #3
on the oil leaks first clean the suspected areas of all oil. a degreaser product or strong soap solution should do the job. then operate for a short time and look for leaks. some leaks are so small that they are not worth fixing (just clean and refil to take care of the lost fluid) but over a long period the appear worse than they are.
KL480 Ventrac tiller
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2022 John Deere 325G Track Loader (A63111)
2022 John Deere...
