Need glow plugs I think!!
/ Need glow plugs I think!! #1
DonWorrell
Pleasant View, TN
Mahindra 3325
Made a dumb mistake. Ran out of fuel with my Iseki TS2205. I have bled the lines and have fuel at the injectors (bolt on top of injector) and it still won't start. I have checked the glow plugs I am only getting 4 or 5 volts. I think I need new glow plugs.
Am I correct. Should I be getting 12 volts at the glow plugs? Another question should it start in the summer warm weather with out glow plugs?
Am I doing everything necessary to bled the lines to get fuel into the cylinders?
Where can I buy new glow plugs?
Don
/ Need glow plugs I think!! #2
maybe the coil wire that shows when it is hot is burned into. That's what happened to mine, I just took a small screwdriver and put the ends together and hit the warmer and melted it back together. That isn't the proper way to do it, but works for me.
I also ran mine out of fuel one time and will never do that again, I had to start at the pump and bleed everything from there to the injectors two times before I could get it to start. Hope this helps some, Nat
/ Need glow plugs I think!! #3
If you're only getting 4-5 volts at the glow plugs, then the glow plugs are probably not the problem. Look ahead of them.
2026 Kearney 96"x 24' Gooseneck Trailer (A64119)
2026 Kearney 96"x...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2018 Bomag BC572 Articulated Refuse Compactor (A61572)
2018 Bomag BC572...
Caterpillar D9R Tractor Parts and Service Manuals (A63117)
Caterpillar D9R...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
New Holland TS6030 (A64119)
New Holland TS6030...
