Need filter numbers quick Please help
/ Need filter numbers quick Please help #1
Bigboyskioti
Just started plowing the drive we have around 8" of snow and a 600' drive. I ran over an old transmission over by the barn. Well all it did was catch the Hyd filter. My Kioti dealer is closed. Anybody know the replacement numbers? From Napa TSC or whereever. Please help..... Thanks. Sorry the tractor is my CK20HST filter number is T4260-38125
/ Need filter numbers quick Please help #2
Wow, I don't think there are any replacements for that Kioti Hydraulic filteer can. I never found one so I just make sure I have one from the dealer ahead of time.
Did you check the receiver piece (plate with threads filter can screws into) Sometimes those get broken in a colllision like that but the good news is they are replacable.
Wait for someone else to confirm my recollection about a substitute filter.
rimshot
/ Need filter numbers quick Please help #3
I'm not aware of any aftermarket filters out there that I would trust or for that matter heard of.
Where are you from?
Yup a pretty bonehead move...... What are you talking about "can" it's the hyd filter underneath, looks like it's just a filter. Not sure about the receiver piece I decided to let wait til tomorrow to see about it. I was hoping to get the drive plowed so the wife could get down in the morning but it looks like I'll be driving her to work......
/ Need filter numbers quick Please help #5
Just searched multiple cross reference charts for oil filters and came up empty. I would call NAPA, TSC, etc. and ask them, they have a bigger database and may be able to find something.
Good luck
/ Need filter numbers quick Please help #6
I am almost certian we have the filter housing in stock if you need one once you check to see the damage.
Let me know if we can help you out...
We will also ship next air day if need be!
You can call Amy or Mark at my store if your dealer can't help you out.
/ Need filter numbers quick Please help #7
Wix (aka Napa's gold) has a thorough filter look-up and cross-reference on their website, WIX filters, WIX oil filters, WIX air filters, WIX fuel filters, WIX Heavy Duty Oil Filters : Filter Look-Up Punch in the part number and see what comes up.
Their database has filters listed for the CK20 HST oil, air, and fuel filters, but didn't have anything for the hydraulics. If your 2006 is like my 2009 than I believe you should have a standard hydraulic filter and a separate finer micron rated HST filter-check which of the two you need!
Got the filter today from the dealer. Was a bear to get everything back together. The aluminum part wasn't broke but the little hard line was bent. Tried to bend it back, got it to where it all would go together. Now I'm not getting fluid to the pump. I have no 3 point, front hydraulic, or drive. Called the dealer he's not sure what's going on. It's like it's air locked. The only other thing we have came up with is the O rings were damanged. I ordered the small hard line and new O rings. Hope this works. I have snow to plow... & more on the way. Any ideas? Thoughts?
Nobody has any ideas on my problem?
/ Need filter numbers quick Please help #10
Sound like it's sucking air and not allowing it to prime it's self..You are headed in the right direction with replacing the steel line and o-rings
Thanks. I was hoping someone would say that. I hate throwing parts at a problem. BUt I can't for the life of me figure that it's anything else. Rick would running the pump dry burn it up? It never stopped moving until I parked it. I only had to go about 20' from where this all atarted.
/ Need filter numbers quick Please help #12
Not really and if it did anything it would just make the hydraulics weak.
That's a relief. Thanks again.
Just thought I'd wrap this up. I bought the small line and new O rings for everything. Got it installed tonight. The "Great Pumpkin" is back in action. Thanks for the help!
/ Need filter numbers quick Please help #15
Thanks for letting us know it is back up and what you have done to fix it. :)
2009 PETERBILT 340 (A60736)
2009 PETERBILT 340...
2016 John Deer 5075E (A60462)
2016 John Deer...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A61567)
Challenger MT275B...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
