Need drawbar dimensions for Deere 790
   / Need drawbar dimensions for Deere 790 #1
CanDo
Michigan
JD790
I hope someone can give me a quick hand.
We got a good rain last night so I went out to roll our 2+ acres of lawn. Unfortunately, the draw bar is missing from my Deere 790! (This is the regular fixed or belly drawbar that comes with the tractor - not an aftermarket 3pt drawbar.) I normally have a rototiller or back blade on the tractor for both use and ballast and haven't used the drawbar in over a year. I never take it out so the only thing I can think of is that the pin fell out and then the drawbar slipped out. Who knows where it could be!
Anyway, I'll make a new one, but I thought I'd try to make one that replicates the original. I remember that there are several holes spread out over the length of the bar and the then there is the size of the bar itself. If you are a 790 owner and have a moment I sure would appreciate some help with the overall dimensions of your drawbar.
To the moderator: Not sure if this belongs here in the "Deere Owning..."? or if it should be in the "Parts/Repairs" or even "Build-it Yourself" section since I do intend to build a new drawbar. If I am incorrect, please do not hesitate to correct.
   / Need drawbar dimensions for Deere 790 #2
The part number is M803613 and the specs are: How got this was go to JDparts.
John Deere - Parts Catalog.
Then this site signed up and put in the part number and got the specs.
jdparts.com
Specification
Weight: 12.41 LBS 5.63 Kg
Hole Size - Tractor End 0.787 IN
Hole Size - Towed End 1.043 IN
Length 19.016 IN
Thickness 1.260 IN
Width 2.008 IN
No. Holes At "A" Tractor End 2.000
Hole Location - Tractor End 3.780 IN
Hole Location - Towed End 1.299 IN
Material STEEL
Finish
Note
Thanks much JD5210. That's exactly what I need. Piece of cake from here on. :thumbsup:
I also appreciate the info on the jdparts.com site as I know it will be a resource for future use. So far I've found the part but haven't figured out how you got the specs yet but I'll keep floundering till I figure it out. In any-event, with the specs you've provided I can work up a replacement.
Thanks again.
   / Need drawbar dimensions for Deere 790 #5
I got the specs, by going to JDparts.com. Selecting English on the next screen in the upper left corner you select sign in/register. Here you register once, select a dealer and answer some questions. The next time when you sign in you will be presented with a screen, were you can enter the part number. A screen will be returned with the cost from the dealer you selected, availability at that dealer and sometimes the specs.
Thanks Clay 47. Should also work.
Thanks JD5210 for the follow-up and the excellent explanation. Upon reading, it quickly was apparent that I needed to "register" in order to get to the info... and there's the rub. After years of an ever increasing barrage of junk mail I have had to change my email and then, in order to protect it, quit registering at sites unless I find it absolutely necessary or at least extremely beneficial. I'll have to think about this one.
Thanks again.
   / Need drawbar dimensions for Deere 790 #8
I don't get junkmail from using jdparts.com. Don't think you will need to worry.
2020 DRAGON ESP...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
Case 930 Tractor (A59814)
Case 930 Tractor...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
