Need ditch / swale advice......
/ Need ditch / swale advice...... #1
coastalguy
I have two rows of young leyland cypress trees, approximately 5 years old and 6 feet tall.
During the winter when the ground gets saturated, some of the trees will blow over a little when the winds kick up. This only happens in the winter and is a direct result of standing water on the root balls.
I need to dig a ditch between the two rows of trees to reduce the water table and firm up the ground. problem is the trees are only 10 feet apart.
I guess I need to rent a mini excavator to dig a ditch?
I would rather cut a swale between the trees but 10 feet is not enough room. I need to address this problem before these trees get larger.
Any ideas??
Thanks!!
/ Need ditch / swale advice...... #2
how long is each row? (just to get an idea of how big the job is)
Any neighbours got similar, may be able to help.
With a mini excavator and bucket you could probably do the swale.
I need to go about 250 ft.
A ditch would work but a swale would look better.
/ Need ditch / swale advice...... #4
I have a row of leyland cypress about 10 years old over 20 ft. tall. Leyland cypress are fast growing and have reputation for blowing over. I have lost a few. Fertilize deep to encourage the root ball to develop roots that can stand the wind and wet soil. I,also, have allowed prickly pear trees to grow up next to the cypress for extra wind buffer and something to lean on. Leyland cypress with their beatiful dense green branches are like sails in the wind when the wind blows hard. In time the root ball will catch up with the foliage and your cypress trees will be less prone to blow over. good luck.
/ Need ditch / swale advice...... #5
The roots should have reached out beyond the root ball by now (5 years).
What equipment do you have? Tractor? middle buster? rear blade?
Pics would help too.
Their growth has been restricted somewhat I believe due to the lack of drainage around the trees.
The roots are a concern which is why I am leaning towards a small ditch between the trees.
I have a tractor but only a mowing deck, no blade.
I will try to get a pic and post it.
/ Need ditch / swale advice...... #7
Any ideas??
Thanks!!
If you have a box scraper and an adjustable arm on your 3pt hitch, go to the web site "Everything Attachments" and view thier video under box scrapers for tractors. That will show you how to dig a ditch with a corner of your scraper. Good luck
/ Need ditch / swale advice...... #8
If it is in a nice landscape setting that you wan't to preserve I would put in a french drain between the trees. This would allow you to forego the unsightly ditch.
/ Need ditch / swale advice...... #9
I think I would be worried digging a ditch with a mini-ex between the trees. You will only be 5' from the base of the tree and root damage would be the concern.
MarkV
Here are some pics....
You can see in the first pic I have planted some small leylands on in October. You will see they have a swale besides them.
The other pics are of my 5 year old trees. Notice how the left hand side is smaller ( I believe due to lack of drainage).
The last pic is a poor attempt to remove standing water with a shovel.
/ Need ditch / swale advice...... #11
Another option is to use a single furrow plow and run it up one way to flip the sod back to one side then back down the same furrow to flip it up the other way. You can then use your FEL to remove the sod. That would give you a shallow swale. Depends how deep you think you'll need it if this is the solution.
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
Lot 602 (A62613)
Lot 602 (A62613)
2016 Great Dane 48ft. T/A Refrigerated Van Reefer Trailer (A64556)
2016 Great Dane...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
1997 Volvo WG Day Cab Truck Tractor (A64194)
1997 Volvo WG Day...
