Need Disc Advice
/ Need Disc Advice #1
MARKV33598
Wimauma, Florida (20 mi SE of Tampa)
1976 Ford 3600 Deisel, 1947 Farmall Cub w/sickle bar mower, 2004 New Holland TN60A
I am looking for any help I can get on what size disc to buy. I bought a NH tn60 back in January and have put about 100 hours on it. I have pulled my 6ft disc burried up the the axles in 1st or 2nd gear hi and can pull a 8ft grove disc in 3rd gear hi. I am getting ready to disc some pasture to plant new grass seed and it is about time I buy my own disc instead of borrowing the neighbors. Also any help or recommendations for a bermuda grass that grows well in Florida would be helpfull. There are only about 500 different seeds available and they are all "THE BEST"
Thank you
Mark V
/ Need Disc Advice #2
When I replace mine I will be looking at Monroe Tuffline Folding or one like it. It allows for more weight on one gang by folding the rear gang over the front. There may be others making a disc like this.
/ Need Disc Advice #3
I don't know the HP of your tractor or if it is 4wd or not. I have 47 hp, 4wd, and I can pull a 10' tandem with no problems in 4wd. I get quite a bit of wheel slip in 2wd. I have never ran out of power with it.
/ Need Disc Advice
The tn60 is 57hp at the motor and 46 at the pto. My neighbor has a big JD 12' disc but I know I couldn't pull that. It is also a 2wd shuttle shift 8X8 trans. Any help will be appreciated
MarkV33598
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2007 Polaris Ranger XP (A65579)
2007 Polaris...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
JOHN DEERE 6105E TRACTOR (A64277)
JOHN DEERE 6105E...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2007 WESTERNSTAR 4900 (A65643)
2007 WESTERNSTAR...
