Box Scraper Need Box Blade Help
/ Need Box Blade Help #1
beersngars
Ohio
Kubota L3400HSD
Thanks to TBN, I have come to the realization I need a box blade. :) My tractor is a Kubota L3400HST. I also have decided not to buy a cheapie and end up regretting it. That said, I do like the looks of the Woods GB series and thought the 60" model would be a good fit. Well I came across a very slightly used GB72 (72") for about $220 less than the GB60 new and $350 less than a new GB72. Is the 72" too much for my tractor? Just as I don't want a lesser box, I also don't want one too agressive/heavy for my tractor. Thanks
/ Need Box Blade Help #2
I think your L3400HST should handle a GB72. Jay
/ Need Box Blade Help #3
I have an industrial gannon H120 box. 66" wide mechanical arm (same as hydraulic, but powered by "armstrong") for the scarifiers. It is over 900#.
Tractor is a L3410 HST with R4's and the loader on it.
It does fine with it, but when pulling a full load (25 cu ft) in the box up a 30degree slope, I loose traction.
You can use the G72, but may have some traction issues. Depends on the dirt you are traveling over and pulling thru.
jb
/ Need Box Blade Help #4
I was in the same boat: I have a JD 3320, so it is comparable HP tractor. I was looking at the "Frontier" brand 72 inch, the dealer had a brand new hold over that he'd sell for $850. Yesterday, I ended up purchasing a barely used Woods GB65 (65 inch) for $600. It is wide enough to cover the tire tracks, wide enough to move some dirt, and I think it was the right choice for me because it is the same blade, just a different color and $250 cheaper. If think the 72" would be a good choice, I know that is the route I would have gone if I wouldn't have found the used GB65.
Good luck.
Thanks for the help. Think I'll wait and see if a 60" or 65" comes along. I want to use it in the woods for trail grooming and feel the narrower box may be to my advantage.
/ Need Box Blade Help #6
Beersngars:
If you really want to make the box blade work well, spend the extra needed for a Top & Tilt. You can make all the adjustments by hand, but you will spend a lot of time off the tractor. I would also go for the 72 inch blade. It gives a little more flexibility working edges, and only 3.5 inches wider on each side.
Steve
/ Need Box Blade Help #7
beersngrs:
I changed my mind about the 72" suggestion; for trail grooming and manuvering in the woods a 60"/65" box blade would be a better choice than a 72". Roots and rocks can really stress any size tractor-box blade set up. The local Land Pride dealer was trying to push a 72" BB on me (He just wanted to move it.). I am currently in the process of widening my "tractor trail" on my property. My GB60 works for me :). Jay
/ Need Box Blade Help #9
A 60 inch is probably the ideal length for the 3400 HST. But! if you can buy a like new GB72 for $350 less than new, your local dealer may give you more than you paid for a trade. Might make your new GB60 less expensive.
Good thought, but it IS my dealer who has the GB72. :(
2006 MACK CV713 (A67714)
2006 MACK CV713...
NEW HOLLAND T4020 TRACTOR (A65057)
NEW HOLLAND T4020...
CAT 963 GP Bucket (A68134)
CAT 963 GP Bucket...
Unused 2021 CID POTSS Skid Steer Quick Attach Conversion Tractor Attachment (A66734)
Unused 2021 CID...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
