need an experianced expert
   / need an experianced expert #11
No, I wouldn't call that OK. There's definitely something amiss with the behavior you describe. If you like the dealer, maybe talk to him, not the SM. He'll listen if he's worth his salt.
I would have thought you would have gotten excessive gear scrub when changing gears to go along with it.
   / need an experianced expert #12
ok,,,,i tried it today and pulled the h/l shifter into neutral and it was a little stickey and of course it rolled back,,,,,,and after it stops rolling and there is no load then either shifter will operate smoothly. on an incline, any incline enough to make it roll even a little, either shifter is sticky, witch ever one i move first and it then releases and rolls when ever i hit neutral on either shifter.
i will talk to him but i was hoping to get an idea of what could cause this, i work on airplanes and they dont have transmissions so im kinda at their mercy and i dont trust the guy that will be doing the troubleshooting.
oh yeah i also forgot to mention this is a garage kept overserviced tractor, it gets plenty of tlc.
   / need an experianced expert #19
This may seem like a dumb question. Are you pushing the clutch in ALL the way?
   / need an experianced expert #20
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
UNUSED JCT SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED JCT SKID...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
Mini Forks (A50322)
Mini Forks (A50322)
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
