need an experianced expert
   / need an experianced expert #31
Just taking some guesses, I dont want to offend anyone, but:
1. It sounds to me like the clutch isnt adjusted right. If the tractor does not roll when you push it in on a hill, then the clutch has to still be engaged, so maybe its not adjusted properly in the pedal linkage or elsewhere. Something you want want to look into as you will burn your clutch up prematurely if this is the case.
2. Is a brake sticking or is the parking brake on? (Just curious)
Hope you get it figured out.
   / need an experianced expert #32
   / need an experianced expert #33
fish_whisperer,
Trying to understand your problem here. Are you saying that the clutch is sticking when you depress it and it only comes back when you move the gearshifter?
here are his tractor specs, says live pto which means to me on all the time.
http://www.mahindrausa.com/Products/df_PRODUCT.aspx?proid=3
If the clutch is sticking and it's adjusted properly may be a lubrication issue. The specs don't say whether it is a dry clutch or not. It says it's dual, which I'm not really certain what that means.
   / need an experianced expert #34
fish_whisperer,
talked with dan smith a few minits ago, going to try something tonight, let you know tomarrow.
   / need an experianced expert #37
It definately sounds like the throwout bearing is bad or going bad. Could be caused by many things, defective from start, pressure plate not exact, etc. Maybe your clutch is not adjusted exactly right. Could also be a slightly warped clutch. Really hard to diagnose without driving it. Has the clutch ever been really hot?
Given your description I would not be overly concerned. With 150 hours it's nowhere near what I'd say broken in. Mine is just getting broken in at 400. You have 2 years left on the warranty, let the shop and owner both know your problem and make them understand that you expect the problem to be fixed if it gets worse.
   / need an experianced expert #38
dan smith explained to me that when it rolls back it changes the pressure on the front of the gears to the back and can make it stick,,,,,,,,,,,"solution" use the brakes when comming to a stop, i know this sounds stupid,, too simple but it works, especially if i give it just enough brake pressure to make the tractor slightly rock like he explained, it works perfectly, keeps the back pressure off the gear and shifts smoothly. i rarely use brakes before, now i will. so a slight change in operator habits........problem solved........
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2018 FREIGHTLINER...
LOT LOCATIONS (A52141)
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
VOLVO L45G RUBBER TIRE LOADER (A51242)
VOLVO L45G RUBBER...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
