Need advice
/ Need advice #1
Floydsneed68
TS 3110 iseki tractor
Need info on my TS 3110 iseki tractor. Oil comes out of my filler tube
/ Need advice
That’s what I thought but looked up the capacity and put the correct amount and it still does it.
/ Need advice
Could it be my valve guides are caked with crud?
/ Need advice #6
In addition to the above suggestions, when you last changed the oil did you drain from BOTH oil drain bolts?
/ Need advice
Didn’t know it had two
/ Need advice #9
If it's 4wd, the driveshaft generally runs between two halves of the oil pan.
That's how my Kioti is. So, if you only pull the one drain plug, you will only get about 75% of the pan empty, and then you added 100%, so you might be at 125% capacity. As noted, check the dip stick. It's not going to be easy to drain just 2 or 3 quarts by pulling the drain plug, might want to consider a hand pump fluid extractor
/ Need advice
I’m going to look right now. Thank you
Doesnt start. No compression. (A64553)
Doesnt start. No...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
Unused 2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
2007 WEEKEND WARRIOR BUMPER PULL (A67714)
2007 WEEKEND...
PALLET OF HEAVYEQUIPMENT PRESSURE WASHER PARTS (A68842)
PALLET OF...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
