LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,276
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Yep, I had the wrong tractor picture in mind.
I agree… it the top link is “up” it will clear the shaft. But what other issues could it cause ? (Unintended consequences!)Have some bar stock that you could use to raise that mounting point?
Or, since that flex hitch can swivel 360*, maybe have it up instead of down? As long as it can still pivot with the dips and lift the mower when needed.
When you lift the mower it should remain level at about a foot off the ground if adjusted properly.
Wrong. Read the manual.The top piece that the top link is attached to is being allowed to rotate down. It is designed to only rotate in the up position. Others have commented and posted pictures on how to prevent this and even to not use the top link.
