Need advice on pin hole in steel hydraulic line JD 755
   / Need advice on pin hole in steel hydraulic line JD 755
If were just a pin hole, maybe, but there is a large scooped out area that the pin hole is in the middle of. I'm beginning to entertain the idea of a hardware store brass 1/2 x 1/2 compression union.
I'll check NAPA for a better 1/2 x 1/2 compression union than a hardware store one.
   / Need advice on pin hole in steel hydraulic line JD 755 #13
I have had good luck with the hydraulic compression fittings. As long as you have the room that is what I would suggest. But I would use one made for hydraulics.
Yes, I'm looking for 'high pressure' one as opposed to brass plumbing/fuel line ones.
   / Need advice on pin hole in steel hydraulic line JD 755 #16
Proper rated compression fitting. Hardware stores probably will not carry them.
I'm heading for a swagelock 1/2" x 1/2" steel union.
   / Need advice on pin hole in steel hydraulic line JD 755 #18
Just remember there is definite procedure to install/tighten the Swagelock fittings. Definite number of flats or rotation of the wrench.
Yes, and anti-galling lubricants. I have on hand some copper anti-seize and Permatex PTFE based sealant. Non-copper is recommended, but it says "stainless steel' on the bottle. I'll have to cut out about 1/2" of the steel tubing, and from drawings I think 2 fully inserted tubes only leaves a 1/4" gap inside the fittinging, so I'm hoping the steel tubing will 'give' 1/4". There are several right angle bends in it so I think I'll be OK. I may have to order the part, so I might have a length of hose made up as a temporary bypass. The steel tubing is 1/2" od and a 3/8" drill bit fits in the end fitting so I'm calling the tubing 3/8" ID. I don't know if 3/8" ID hose is sufficient and available, or if I should go up the 1/2" ID hydraulic hose. As it is a low pressure line, I'm also thinking of 1 or 2 braid hose, and not anything stronger since it on the lower pressure side of the hydraulic system.
Ended up with a Parker Ferulok. Hope I can meet the exacting preparation standards they say these things say require.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Toro Mower (A50324)
Toro Mower (A50324)
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
