Need advice on pin hole in steel hydraulic line JD 755
   / Need advice on pin hole in steel hydraulic line JD 755
If were just a pin hole, maybe, but there is a large scooped out area that the pin hole is in the middle of. I'm beginning to entertain the idea of a hardware store brass 1/2 x 1/2 compression union.
I'll check NAPA for a better 1/2 x 1/2 compression union than a hardware store one.
   / Need advice on pin hole in steel hydraulic line JD 755 #13
I have had good luck with the hydraulic compression fittings. As long as you have the room that is what I would suggest. But I would use one made for hydraulics.
Yes, I'm looking for 'high pressure' one as opposed to brass plumbing/fuel line ones.
   / Need advice on pin hole in steel hydraulic line JD 755 #16
Proper rated compression fitting. Hardware stores probably will not carry them.
I'm heading for a swagelock 1/2" x 1/2" steel union.
   / Need advice on pin hole in steel hydraulic line JD 755 #18
Just remember there is definite procedure to install/tighten the Swagelock fittings. Definite number of flats or rotation of the wrench.
Yes, and anti-galling lubricants. I have on hand some copper anti-seize and Permatex PTFE based sealant. Non-copper is recommended, but it says "stainless steel' on the bottle. I'll have to cut out about 1/2" of the steel tubing, and from drawings I think 2 fully inserted tubes only leaves a 1/4" gap inside the fittinging, so I'm hoping the steel tubing will 'give' 1/4". There are several right angle bends in it so I think I'll be OK. I may have to order the part, so I might have a length of hose made up as a temporary bypass. The steel tubing is 1/2" od and a 3/8" drill bit fits in the end fitting so I'm calling the tubing 3/8" ID. I don't know if 3/8" ID hose is sufficient and available, or if I should go up the 1/2" ID hydraulic hose. As it is a low pressure line, I'm also thinking of 1 or 2 braid hose, and not anything stronger since it on the lower pressure side of the hydraulic system.
Ended up with a Parker Ferulok. Hope I can meet the exacting preparation standards they say these things say require.
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
SHOULE RM8080 LOT NUMBER 129 (A53084)
SHOULE RM8080 LOT...
2019 Honda CRF1000L Motorcycle, VIN # JH2SD0409KK300478 (A51573)
2019 Honda...
2013 JOHN DEERE 8235R LOT NUMBER 205 (A53084)
2013 JOHN DEERE...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
City of Buckhannon - Power Curber 5700 (A52384)
City of Buckhannon...
