Need advice on loader hooks.
/ Need advice on loader hooks. #1
glagen
Hopedale, MA
JD 4310 & X595
I want to have some clevis hooks welded on my loader bucket. Can anyone give me some advice on how many and what size. I have a heavy duty 4" X 30' tow strap and I plan on using it to move rocks around for walls as well as lifting balled trees for planting. I don't think the strap loops will attach very well to 3/8" hooks normally used for chains so I probably need to install at least one hook in a larger size. I might use a chain on occasion but chains can be nasty when they break so I generally avoid using them except to pull logs from behind. Many thanks.
Steve Z
/ Need advice on loader hooks. #2
I use a strap like you describe. I hook mine to the cast hinge on the back of the bucket. Don't tell anyone but I have even moved small round bales that way! With a sig pic like mine, do you really think I am ALWAYS safe?
But really, it has worked well for me..
I would try that before welding, you might at least get a better idea what you'd like that way....
/ Need advice on loader hooks. #3
A pretty common method is to have a weld on 3/8" hook aligned with each arm and a slip hook in the center for things like straps, etc.
A good place to find weld on hooks is AW Direct.
Good luck with whatever you decide. I hope this helps. /forums/images/graemlins/smile.gif
/ Need advice on loader hooks. #4
It seems logical to me that you might want to reinforce the top edge of the bucket along the full length, then have a technician or fabircator weld on "C" or "H" channels with drilled holes that would take a 1/2" or 5/8" pin. That way you could simply pin either hooks or clevises onto the top edge of your bucket depending on your use. It's hard to explain, but I can see it clear as day in my imagination /forums/images/graemlins/crazy.gif
/ Need advice on loader hooks. #5
Good idea -bigpete /forums/images/graemlins/wink.gif It would have to be fairly thick and deep C channel as to not bend and have enough room behind the pin for the strap
/ Need advice on loader hooks. #6
I would have to reccomend a set of pallet forks..I use them more than the bucket, many more uses..
/ Need advice on loader hooks. #7
I install two pieces of angle iron on the top to give strength to the top of the bucket, then I install two large hooks on the outside for straps and a close hook in the center for chains.
It works well for me
Dave in NH
Mahindra 2810HST , Kioti DK-40
/ Need advice on loader hooks. #8
and a second picture
Thanks everyone for your advice. BTW, I located some neat weld-on hooks at: CM Industrial
A little on the pricey side - $44 for a 1 ton but I think it will look better than a std clevis welded on. Local company claims most folks have only one on their buckets, located in the center. I will go that route for now and add more if necessary.
Steve Z
2015 Ford Edge SUV (A61574)
2015 Ford Edge SUV...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
MINI FLAT BOTTOM GRAPPLE (A61572)
MINI FLAT BOTTOM...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
1988 Ford Mustang GT Convertible (A61574)
1988 Ford Mustang...
1999 GMC C7500 Dump Truck (A61573)
1999 GMC C7500...
