Need advice on grain drill for haying
   / Need advice on grain drill for haying
Robert_in_NY said:
Umm, my test include that information also. It is the only test they do:eek:
I would still ask around next time and see if you can get this done cheaper. Otherwise send your sample to Cornell:D
Thanks for the info. I'll check around. Fortunately the next testing is a year away so I have time to find another lab.
   / Need advice on grain drill for haying #32
Soil Testing
Im curious about the soil test results. I have never paid attention beyond how much NPK or lime I need.
What would you do with all the other information?
I can see it useful in an intensive vegetable crop like strawberries, lettuce, tomatos and the like.
rdbigfarmboy said:
Soil Testing
Mostly put it in the file. As I said earlier, I'll go with the less comprehensive tests next time.
   / Need advice on grain drill for haying #34
rdbigfarmboy said:
Soil Testing
You are right, the rest of this information is important but not so much so to some crops. It helps my fertilizer dealers mix a proper blend for me to spread and it also tells them if I need to worry about anything in particular. I don't understand some of it but my dealers do and they advise me properly.
   / Need advice on grain drill for haying #35
Can anyone tell me how to adjust the feed gates when drilling spring oats with the JD 8200 grain drill? I was told to just close them which I will try and experiment on the driveway before heading for the field. Thanks for any advice.
   / Need advice on grain drill for haying #36
You should consider posting your question as a single thread with a highlight of the drill model in the title. That way, folks with experience using that model will take note and offer suggestions.
AKfish
   / Need advice on grain drill for haying #37
When sowing clean oats with a JD grain drill feed gates should be in #1 position which is at the very top. This info is IIRC on the feed chart in seed box cover.
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2013 Cadillac SRX SUV (A56859)
2013 Cadillac SRX...
SNAPPER ZERO TURN LAWN MOWER (A52708)
SNAPPER ZERO TURN...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A58017)
2016 FREIGHTLINER...
2017 Jacobsen Greens King IV Plus Reel Commercial Mower (A56857)
2017 Jacobsen...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
