Need advice on grain drill for haying
   / Need advice on grain drill for haying
Robert_in_NY said:
Umm, my test include that information also. It is the only test they do:eek:
I would still ask around next time and see if you can get this done cheaper. Otherwise send your sample to Cornell:D
Thanks for the info. I'll check around. Fortunately the next testing is a year away so I have time to find another lab.
   / Need advice on grain drill for haying #32
Soil Testing
Im curious about the soil test results. I have never paid attention beyond how much NPK or lime I need.
What would you do with all the other information?
I can see it useful in an intensive vegetable crop like strawberries, lettuce, tomatos and the like.
rdbigfarmboy said:
Soil Testing
Mostly put it in the file. As I said earlier, I'll go with the less comprehensive tests next time.
   / Need advice on grain drill for haying #34
rdbigfarmboy said:
Soil Testing
You are right, the rest of this information is important but not so much so to some crops. It helps my fertilizer dealers mix a proper blend for me to spread and it also tells them if I need to worry about anything in particular. I don't understand some of it but my dealers do and they advise me properly.
   / Need advice on grain drill for haying #35
Can anyone tell me how to adjust the feed gates when drilling spring oats with the JD 8200 grain drill? I was told to just close them which I will try and experiment on the driveway before heading for the field. Thanks for any advice.
   / Need advice on grain drill for haying #36
You should consider posting your question as a single thread with a highlight of the drill model in the title. That way, folks with experience using that model will take note and offer suggestions.
AKfish
   / Need advice on grain drill for haying #37
When sowing clean oats with a JD grain drill feed gates should be in #1 position which is at the very top. This info is IIRC on the feed chart in seed box cover.
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
Front End Loader Fork Attachment 20,000 lbs 5 foot (A59213)
Front End Loader...
POULAN CHAINSAW, BLOWER, (3) WEEDEATERS (A58374)
POULAN CHAINSAW...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
TANK MANIFOLD (A58214)
