Need advice on 30 -40hp tractor purchase
   / Need advice on 30 -40hp tractor purchase #11
Wonder what depth your snowfalls are and how wet the snow is. You might have to make a decision on these facts.
   / Need advice on 30 -40hp tractor purchase #12
No mention of how long the driveway? Solution for 50' would be different from 1000'. The comment stating concrete would be in the range of cost of a tractor plus snowblower suggests much less than 1000'.
   / Need advice on 30 -40hp tractor purchase #13
I had a Rhino 950 that I used behind my TN70D tractor. I used it to cover power line ditches. It was a wonderful, versatile blade, very stout. Mine was set up to control all functions from inside the cab. I can see it being very effective as a snow clearing tool.
Tim
   / Need advice on 30 -40hp tractor purchase #14
I have a hydraulic front mount blower run off of a rear hydraulic powerpack. It takes about 2 hours to set up and remove At end of season.
does a great job at moving lots of snow. I switched from Rear blower due to neck issues about 9 to 10 years ago.
i could not use a mid pto style front blower cause of my need to clear tall drifts of snow when my buildings shed, so the horses can get out and so that there is an area for more shedding to occur..
   / Need advice on 30 -40hp tractor purchase #15
I see that the MF 1500 series have front mount snow blowers.
I have had very good luck with both my Massey tractors. The cab model is priceless, although for me its protection from sun and heat versus cold.
   / Need advice on 30 -40hp tractor purchase #16
My vote would be for a larger frame 40hp. You will appreciate the extra traction. I have a Rear Pull snowblower and I love it. They are more prevalent in Canada than the US. I have a MK Martin/Meteor. Pronovost, Normand, Lucknow, Erskine, Farm King, Smyth Welding and Bush Hog all make them.
The rear pull is fast and you really don't have to look back because you are driving forward.
   / Need advice on 30 -40hp tractor purchase #17
   / Need advice on 30 -40hp tractor purchase #18
   / Need advice on 30 -40hp tractor purchase #19
but rear pulls suck when you get 36' snowfall overnight like we have had in the past. also, suck when trying to clear snow drifts
   / Need advice on 30 -40hp tractor purchase #20
Yep. We don't have 36" snowfalls in WI, so Rear Pulls work great!
This would work great with deep snow and high drifts.
2020 DRAGON ESP...
2011 MERCEDES-BENZ E-Class (A56859)
2011 MERCEDES-BENZ...
SNAPPER ZERO TURN LAWN MOWER (A52708)
SNAPPER ZERO TURN...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2014 Ford Escape SE (A56859)
2014 Ford Escape...
1992 Ford L900 Cab Chassis with Low Milage Cummins (A56435)
1992 Ford L900 Cab...
