Need advice on 22.5" truck tires and potential for dry rot.
   / Need advice on 22.5" truck tires and potential for dry rot. #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have an older Ford 600 truck that I replaced the widowmaker wheels with 22.5 inch tubeless. The front steering are 9R-22.5 and in good shape.
For the rears, it's easier to find 235-80-22.5 radials and they are very close to the same size as the 9R-22.5.
The question is, how old is too old when it comes to used tires? If they look good --crack wise--should I presume they are good? I found some that are 11 years old--Michelins--and they look great but is that too old for a used tire? Is there an age when cracking starts to appear?
Any advice appreciated.
   / Need advice on 22.5" truck tires and potential for dry rot. #2
The trouble with tires is you can never tell by looking at them. Sometimes, the trouble starts from the inside or is the integrity of the rubber itself. Are the tires 'hard' or are they still relatively flexible? Used tires are always a crapshoot. I bought a good looking used tire that didn't last 2 miles, whereas, an 'old' ugly looking tire on my trailer got well over 5000 (and this is only since I bought the trailer). If your weight and speed are going to be kept low, the tires might last a while (how much tread is still remaining?) But, if you will be hauling heavy loads for long distances (allowing the tires to get hot), I recommend investing in some new tires sooner rather than later.
Hawk
   / Need advice on 22.5" truck tires and potential for dry rot. #3
Around here no tire shop or mechanics will touch a tire over 6 years old except to walk it to the dumpster.
Chris
Good advice. I'm listening.
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2015 Tiger Trailers Inc. Gooseneck T/A Enclosed Trailer (A51692)
2015 Tiger...
2005 Butler Pole Trailer, 25000 GVWR (A52384)
2005 Butler Pole...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
