Need advice on 22.5" truck tires and potential for dry rot.
   / Need advice on 22.5" truck tires and potential for dry rot. #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have an older Ford 600 truck that I replaced the widowmaker wheels with 22.5 inch tubeless. The front steering are 9R-22.5 and in good shape.
For the rears, it's easier to find 235-80-22.5 radials and they are very close to the same size as the 9R-22.5.
The question is, how old is too old when it comes to used tires? If they look good --crack wise--should I presume they are good? I found some that are 11 years old--Michelins--and they look great but is that too old for a used tire? Is there an age when cracking starts to appear?
Any advice appreciated.
   / Need advice on 22.5" truck tires and potential for dry rot. #2
The trouble with tires is you can never tell by looking at them. Sometimes, the trouble starts from the inside or is the integrity of the rubber itself. Are the tires 'hard' or are they still relatively flexible? Used tires are always a crapshoot. I bought a good looking used tire that didn't last 2 miles, whereas, an 'old' ugly looking tire on my trailer got well over 5000 (and this is only since I bought the trailer). If your weight and speed are going to be kept low, the tires might last a while (how much tread is still remaining?) But, if you will be hauling heavy loads for long distances (allowing the tires to get hot), I recommend investing in some new tires sooner rather than later.
Hawk
   / Need advice on 22.5" truck tires and potential for dry rot. #3
Around here no tire shop or mechanics will touch a tire over 6 years old except to walk it to the dumpster.
Chris
Good advice. I'm listening.
2010 Talbert Lowboy T(4)-55SA-BC-HBG (A52384)
2010 Talbert...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
