Buying Advice Need Advice for tractor to support 20 acres
   / Need Advice for tractor to support 20 acres #51
finish mowers are great for lawn mowing. If that's what you've got.. 12ac of lawn.. then a finish mower sounds like the ticket.
If you'v got 12 ac of pasture an stemmy weeds.. it will be extra abuse on the finish mower. The more HD models may stand up to that sort of use.. etc.
Soundguy
Yea, i think a finish is the ticket, but what can i pull behind me? only a 6' (/:{ or a 7' :) also, how fast can i go with this (mph) ???? thx :)
   / Need Advice for tractor to support 20 acres #53
It all depends how much HP at the PTO and how tough is the stuff you are cutting.
Bob
It'll be grass/weeds using a tc40da
   / Need Advice for tractor to support 20 acres #55
Sounds like a 7' finishing mower to me.
MPH will affect cut look. I'd guess around 4-5 mph may be ok.. but it will really depend on your terain, and foliage, and mower cut quality and construction, blade type / condition.. etc. ( in short.. lots of variables on how fast you can cut.. )
Soundguy
Hi All, I'm in Indiana, closed on the home yesterday @ 9am, took tractor delivery at 12 noon! Was delivered on a tractor/trailer (40'?) only think in the truck from N.C. I though i might damage the trailer 'cause it was all the way up front w/ the loader down. but i went in range I/Turtle ;) It was like mission imposible -- i had to make it out of the trailer b4 the diesel exhaust sends me to see my maker ;) I only played around for like 10 minutes because i don't take possession of the home until Monday. So i'll play around a lot more then! I also wanted to read the operators manual b4 I do anything incorrect (like change from I to II speed while moving... ) I did it, but that's why i'm reading the manul now :eek: Hope to post some pictures, won't be pretty 'cause everything like dead for the fall -- trees have no leaves, some weeds are all brown, etc.. Until next week... -Tim
   / Need Advice for tractor to support 20 acres #58
Congratulations, Tim! It sounds like you have everything coming together. We'll just call you Tim the "toolman". Okay?
Don't worry about pictures. Your place will just look like everyone else's when they first got it. Mine looked like an overgrown jungle.
Tim the toolman's fine ;) Never wrenched on a diesel before though! Im told I have a fox den in my woods... Should i dig it up to chase 'em elsewhere? I wanted guinea hens not fox food when i finally relocate...
   / Need Advice for tractor to support 20 acres #60
Congratulations on your delivery....and arrival.!
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
43017 (A51691)
43017 (A51691)
2014 Freightliner M2 106 Altec DC47T Insulated Derrick Digger Truck (A50323)
2014 Freightliner...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
