Comparison Need advice - Compare JD 3series to ???
   / Need advice - Compare JD 3series to ??? #11
I ended up ordering the 3046R yesterday. I've also ordered the JD front snow blower and FEL.
And lastly, I've decided to purchase a grapple system from Artillian.
I really appreciate the feedback.
Jim
Good luck with your new "Big Boy Toy"
In the past, there was a "hard lines" option that mounted on the FEL arm to get additional hydraulic power to the front for a SB chute or Grapple. If required for your intended future uses check to make sure you have that box ticked on the order form.
   / Need advice - Compare JD 3series to ??? #12
Maybe you mow at a faster speed or cut lower than I do when you mow. The 3046r is 9hp more than your 3032 or 27% more. My tractor will bog down in thick stuff if I go to fast. I also do not have a rubber deflector on the back of my tarter round back mower. I think this helps. It also seems to have more power at the pto when I am in two wheel drive. I am not sure it does or it is my imagination.
2018 John Deere Z997R (A53317)
2018 John Deere...
2004 950M Towable Cement Mixer (A55851)
2004 950M Towable...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
2017 JOHN DEERE 50G EXCAVATOR (A52707)
2017 JOHN DEERE...
DONE RIGHT DOCTOR POWER DISC MOWER (A57192)
DONE RIGHT DOCTOR...
