Comparison Need advice - Compare JD 3series to ???
   / Need advice - Compare JD 3series to ??? #11
I ended up ordering the 3046R yesterday. I've also ordered the JD front snow blower and FEL.
And lastly, I've decided to purchase a grapple system from Artillian.
I really appreciate the feedback.
Jim
Good luck with your new "Big Boy Toy"
In the past, there was a "hard lines" option that mounted on the FEL arm to get additional hydraulic power to the front for a SB chute or Grapple. If required for your intended future uses check to make sure you have that box ticked on the order form.
   / Need advice - Compare JD 3series to ??? #12
Maybe you mow at a faster speed or cut lower than I do when you mow. The 3046r is 9hp more than your 3032 or 27% more. My tractor will bog down in thick stuff if I go to fast. I also do not have a rubber deflector on the back of my tarter round back mower. I think this helps. It also seems to have more power at the pto when I am in two wheel drive. I am not sure it does or it is my imagination.
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
2011 Audi Sedan (A56859)
2011 Audi Sedan...
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
UNUSED FUTURE FT15 EXCAVATOR (A57192)
UNUSED FUTURE FT15...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
