Need advice - 15-20HP
   / Need advice - 15-20HP #21
I’ve got a plastic hood on my JD, it holds up fine and looks new. I had a Kubota BX when they had plastic hoods. The paint was faded but it held up fine, the plastic surrounding the engine not so good. The newer ones are metal.
   / Need advice - 15-20HP #22
Whatever you get I would suggest you get a tractor with a Front End Loader, an FEL. Even though you may think you won't use one much it has been my experience that the FEL gets used a lot. They are remarkable labor saving devices. Not just for moving dirt. Moving rocks, moving trees or bushes in pots that need planting, moving brush, moving tree limbs from blow downs, moving garbage cans down to the end of a long driveway, all things that the FEL is really useful for. If it's heavy or bulky the FEL generally comes into play. I use the FEL on my Yanmar YM2310 way more than I thought I would.
Eric
Not to mention the price of loaders has gone crazy over the last 5 years. Holding off is probably not a good idea.
It is clear that a new machine will not meet my budget. May need to re-evaluate.
So back to the old machine approach. I know it matters on how it was maintained and used. That being said, is there a threshold in hours I should try to stay under?
   / Need advice - 15-20HP #24
Depending on prior maintenance ... My current Massey Ferguson GC 1725 MB I bought new in 2022 has over 730 hours and running strong, this summer I bought a Kubota L5030 HSTC which was owned by the State College and well maintained and it had 3900 hours on it, still running strong!
   / Need advice - 15-20HP #25
My JD 855 had 2,000 hours on it when I bought it, but it had been a county tractor so it had been maintained. I replaced the water pump (not leaking but a real loose shaft), fixed a metal hyd line, new rear tires with ballast, and new seat, but besides oil/fluid changes - that's it. FEL is a "must have", for use and resale value. Like mentioned, it gets used alot. I even used mine to carry the gun safe from the trailer to the house.
   / Need advice - 15-20HP #27
With it being that new, and if you wanted to add a loader or mmm you probably could, but would probably be cheaper to buy it all together ... But you could go like I did, I found the tractor and bought it, then saved and bought the 90" mower ...
But if you "buy it cheap" because of lack of loader, and don't up grade, if you go to sell, it will be harder to find someone that's willing to buy it, and it will be also "sell it cheap" when you do eventually find a buyer ...
I plan to keep my no loader Kubota until I die, so I'm not worried about re-sale value, it my big lawn mower!
   / Need advice - 15-20HP #28
I realize the search is in the early stages but this low hour unit gives me hope. I know it has no loader and mower.
I am renting an hour away.
I've seen MMM's for sale for this series of JD, but not so much for FELs. A FEL alone for one of these is in the $4K range I'd imagine.
I’m not worried resale for the same reason!!!
Not saying it’s a go. I was just a little surprised that I found one in the price range knowing that the extras would cost me
Should I also be looking at Yanmar? Seems that they are reliable. After all, aren't they quite similar to Deere in many ways? How would parts availability be impacted on Yanmar vs Deere (obviously less dealers but are they easy to source)?
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
