Front-End Loader Need a new pump for my 772A loader
   / Need a new pump for my 772A loader #1
JD2150 and JD2305
Having picked the best time of the year (20 miles from Canadian border) to do maintenance on a piece of equipment using hydraulics I am getting the cylinders repacked on my loader. Figured it would be a good time to replace the 40+ year old front mounted hydraulic pump as well. Loader is mounted on a Ford 4600. Hoping someone might have a good source for picking up one of these pumps. Thanks
   / Need a new pump for my 772A loader #2
If its a generic pump you can check out Surplus Center for various aftermarket pumps. If you're looking for an exact replacement then a picture of the pump and any info stamped into it would be helpful to identify a replacement.
Edit: you could also take it out and have a hydraulics shop rebuild it.
The rebuild part is a good idea, hadn't thought about it considering it's age. The part number is SML5638.
   / Need a new pump for my 772A loader #5
I checked 2 places and prices were $650 and the other was nearly $1k. I'd call around and ask about getting it rebuilt for those prices. If your handy you might even be able to do it yourself with a little patience.
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
BOX BLADE (A58214)
BOX BLADE (A58214)
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2013 KENWORTH T880 HYDRO EXC VACUUM TRUCK (A59823)
2013 KENWORTH T880...
