Front-End Loader Need a new pump for my 772A loader
   / Need a new pump for my 772A loader #1
JD2150 and JD2305
Having picked the best time of the year (20 miles from Canadian border) to do maintenance on a piece of equipment using hydraulics I am getting the cylinders repacked on my loader. Figured it would be a good time to replace the 40+ year old front mounted hydraulic pump as well. Loader is mounted on a Ford 4600. Hoping someone might have a good source for picking up one of these pumps. Thanks
   / Need a new pump for my 772A loader #2
If its a generic pump you can check out Surplus Center for various aftermarket pumps. If you're looking for an exact replacement then a picture of the pump and any info stamped into it would be helpful to identify a replacement.
Edit: you could also take it out and have a hydraulics shop rebuild it.
The rebuild part is a good idea, hadn't thought about it considering it's age. The part number is SML5638.
   / Need a new pump for my 772A loader #5
I checked 2 places and prices were $650 and the other was nearly $1k. I'd call around and ask about getting it rebuilt for those prices. If your handy you might even be able to do it yourself with a little patience.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 Frontier FL1061S Hydraulic Flail Mower (A56438)
2024 Frontier...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2016 Doyle 10T Tender (A56438)
2016 Doyle 10T...
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A59230)
2004 Pierce Tilt...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
