Need a new chain saw 20" should do
   / Need a new chain saw 20" should do #21
Good luck with your new 390 it should serve you well for many years. In my part of the country Stihl has the best dealer support hands down. Husky is a good saw as well as Shindiawa and Dolmar but dealer support is very spotty at best, and the Husky saws at the Box stores are not the pro models and they typically have no support at all. My dealer is a Kubota, New Holland tractor dealer but they have dedicated saw repair people trained at the gold level at the Stihl factory. Again, good luck with you saw and be safe.
   / Need a new chain saw 20" should do #22
The 390 will do you well. You can put at least a 24 inch bar on it. I have a 24 inch bar on my 036 that I have had for over 15 years. It is stihl going strong. I couldn't help it. I use skip tooth chisel chain. It is very important to keep that chain sharp. Make sure you clearly mark your mixed oil container and don't forget the 2 cycle oil. The dealer adjusted the carberator just a tad rich when I first bought it. He said the saw lasts longer that way. I haven't touched the mixture screws. I cut about 5-6 cords of firewood a year.
   / Need a new chain saw 20" should do #23
I agree with the Stihl thing and have a 045 super that is awesome! 10 years ago I bought a Poulan Wood Shark, 14 inch bar and have cleared and trimmed my eastern Oregon mountain wooded property and hauled it on atv for clearing trails in the spring, cutting fence posts, you name it its done it, never missed a beat, several new chains, gas and oil. It always starts and has plenty of power. Cost was about 100 bucks new. Could not ask for a better compact saw.:D
   / Need a new chain saw 20" should do #24
I own two Stihl's and they are great. One of my best buddies is a tree cutter for over 25 years and he swears by Husky's. Ford v. Chevy, Democrat v Republican, Coke v Pepsi, McDonalds v Burger King...all of these pale by comparison when trying to figure out women!
   / Need a new chain saw 20" should do #25
Reminds me of one of my all-time favoritie "stories"...
This old farmer had done a very brave and remarkable feat -- rescuing a whole school bus load of children from a bus that had overturned and then caught on fire in the field next to his house. The front, folding doors had been crushed and blocked when the bus overturned. The scared, panicked children couldn't get the emergency door in the back open, and they were trapped on the bus. The farmer ran over, managed to get one of the window exits open, and pulled child after child out of the overturned bus. He even talked two of the larger boys into pulling the unconscious driver back to the window, where he pulled them all out just before the bus was enveloped in flames...
Not only did this heroic act catch all the local media's attention, it also caught the attention of someone even more important. That night, while the old farmer was sleeping, God came to him in his dreams...
God said to the old farmer, "Because of your unselfish bravery, risking your own life and suffering cuts and burns to rescue all those poor, trapped children, I'll grant you any single wish that you can come up with. Just think it over very carefully, because you only get one wish..."
The farmer thought quietly for a few moments, then said, "God, will you build me a bridge to Hawaii? I've always wanted to go to Hawaii since I saw it on television years and years ago. I watch every National Geographic or travel special I can see about Hawaii. But, I'm scared to death of airplanes and ships make me deathly sick, so I can't even take a ship over there. But, if you'd build a bridge to Hawaii, I could drive over there and see Hawaii for myself..."
God replied, "Do you realize how difficult it would be to give you what you're asking for? It's thousands of miles to Hawaii, across some of the deepest parts of the Pacific Ocean, ans there's still active volcanoes on the ocean floor -- miles down there -- and the ocean floor keeps shifting all the time. Do you have another wish, that might be a little bit easier to accomplish?"
The farmer said, "Well, my second thought was -- could you help me understand women? I've never been able to, as hard as I've tried..."
To which God replied, "Do you want that to be a two-lane or a four-lane bridge?"
   / Need a new chain saw 20" should do #26
Slade said:
Would you guys go with a Stihl or is there something better now? TIA
Just bought a Domar 5100 saw from cragslist. I'm very impressed with the power. This saw is set up with a 18", 3/8 pitch chain. To me a 20' requires a 70cc powerhead. I like smaller bars on saws.
   / Need a new chain saw 20" should do #27
Absolutely priceless story...thanks for the laugh
   / Need a new chain saw 20" should do #28
swines said:
Husky's run slightly higher RPM = higher chain speed = faster cutting....
Time = money.
Quality on both is equal. I've had a Husky since 1981 ... still works like new. Also have many Stihl products - both manufacturer's products work fine.
Would buy a saw by which company's local dealer is the best.
WHat if your local dealer is a dealer for BOTH?
   / Need a new chain saw 20" should do #29
I don't know... I am still using the Homelite ZIP saw my grandfather bought in 1961. I had to put a new bar and clutch on it 15 years ago, since the original style chain was no longer available. It is starting to run a bit rough, I suspect it needs the carb rebuilt, but nobody wants to touch an 'antique'.
500BBL FRAC TANK (A58214)
500BBL FRAC TANK...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
Step Van (A56858)
Step Van (A56858)
JOHN BLUE 1000 GALLON NURSE TANK (A52708)
JOHN BLUE 1000...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
