Need a new chain saw 20" should do
   / Need a new chain saw 20" should do #11
scgargoyle said:
S-T-I-H-L.... 4 letters??
The Stihl MS-361 is a top pro model saw for a 20". A bit spendy, though.
I just re read my post and saw what my fat finger had done , clipped the 4 when i went for the 5 . I thought i'll fix that before anyone see's it.......:eek: It's OK , i can count to five if i take my shoes off...
   / Need a new chain saw 20" should do #12
Stihl 390 with 20" bar and 3/8" chain, it will be the last saw you ever need.
   / Need a new chain saw 20" should do #13
Not to diss a Stihl -- I own one, in addition to a new Husqy -- but this sounds an awful lot like "the only tractor to buy is John Deere"...
Both are misleading statements, IMO. Both Stihl and John Deere are overall good products, but at some price/performance points, other brands are better...
IMO, Stihl vs Husqy is an awful lot like Ford vs Chevy...
   / Need a new chain saw 20" should do #14
I will throw dolmar out there as well. Definatally worth a look if you have a dealer. Good value for a pro grade saw.
If you are just an average firewood cutter that cuts 10 or so cord a year, any pro saw should last a lifetime if cared for.
It's a lot like buying a tractor...If you have a good dealer in your area that stands behind their product, go with them. Stihl, Husky, dolmar, they all make excellent saws but without a decient dealer I wouldn't buy one. I chose dolmar because of the quality of the dealers in my area compaired to the stihl and husky dealers.
Go to the dealers, handle the saws, use them, and get a feel for the dealers. You can't go wrong with any of the brands mentioned.
   / Need a new chain saw 20" should do #15
Agree... and don't overlook the Dolmars sold as Makita brand or the Huskies sold as Jonsered...
My friend has had the large Makita (i.e. Dolmar) for several years and absolutely loves it. It's been absolutely troublefree and cuts like crazy...
Follow up: was at my tractor dealer yesterday and turned out he's the local elite and service dealer for Stihl. Ended up with an MS390.
Thanks for all the comments.
   / Need a new chain saw 20" should do #17
Being a logger from the NW, I have to go with the Stihl. I have had Mccullahs, Homelites, Echos, johnsered and huskys, I can honestly say that the stihl has been the one that has held up the best. Of course the technology has come a long way with saws too. Right now I have 5 s200 weedeaters, a pole saw, hedge trimmer, blower, an 019, 028,031 and an 066. The thing is with any one of these, they always start, with the simplest of maintenance. The one thing you must do for yourself though, is get one from a saw shop, not the local shop that sells tractors and farm equipment. If you ever have any trouble, a saw dealer will give you much more satisfaction on repairs. When you get it, be sure to get the chaps and protective headgear. I have seen some nasty cuts and scars on fellows that knew what they were doing. These things are not backyard toys. A small saw will cut you just as fast as a large one. Be aware and take the time to make yourself a way out if you are felling trees. Do not stand there and watch it fall, something will come out of the top or the top of another tree and hit you on the head as you watch the on go down. It does happen. Work safe, your family depends on it.
   / Need a new chain saw 20" should do #18
You want the best .................STIHL!!!!!!!!!!!!!!!!!!!!!!
   / Need a new chain saw 20" should do #19
Ever watch the series Ax Men on the History channel? For them its Stihl or Husky, but it seems like I see more Huskys on the show than Stihl.
   / Need a new chain saw 20" should do #20
Husky's run slightly higher RPM = higher chain speed = faster cutting....
Time = money.
Quality on both is equal. I've had a Husky since 1981 ... still works like new. Also have many Stihl products - both manufacturer's products work fine.
Would buy a saw by which company's local dealer is the best.
Electric Utility Cart (A56857)
Electric Utility...
2304 (A58376)
2304 (A58376)
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
Mini Plate (A57149)
Mini Plate (A57149)
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2000 International 4800 (A57148)
2000 International...
