Need a Ford
   / Need a Ford #1
murphy1244
Super Star Member
Ohio
Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Looking for a ford 9n or 8n To run a 6 foot rotary cutter. Ohio area. Someting nice. Pm Me.....
   / Need a Ford #2
sorry.. your message doesn't make sense :)
a ford 9n, 2n, or 8n simply doesn't have sufficient pto hp to adequately run a 6' rough cut rotary cutter.. or lift it for that matter.
a 6' finish mower would be acceptable.
I reccomend you look into the 53-64 years if you NEED a 6' mower.
while a naa, or 6xx / 7xx / 2000 4 cyl WILL run a 6' mower.. I'd suggest a 8xx, 9xx / 4000 4 cyl. If diesel, it will be a 59 or newer, and if going diesel, I'd stick with the 8xx/9xx/4000 as it will have the easier to get part$ for 172ci engine.
given a choice of any of those model for mowing.. i'd go for a 4000 rowcrop with wide OR narrow front end. if you need to maneuver.. go narrow.. if maneuvering is not a big deal.. go wide.
the rowcrop gets you up higher to see better. I'd also reccomed a 5 speed model ( denoted by a *5* or *6* on the 55-62 models.. preferably the *6* dual clutch if possible.. and power steering. If you find a 4 cyl 000 model and it is 5spd with original trans.. it will be a dual clutch.
any of those of those should be able to be found in the 3000$ or less range, depending on local market...
if you have any questions, just post em.... i got a barn full of fords...
soundguy
   / Need a Ford
Thanks Sound guy, So I guess scratch that. Was looking fer sumting old to mow with so I could just leave the rotary on it. Thanks for setting me straight.:)
   / Need a Ford #4
8n made it to 52.
bump to 53 and that gets you a NAA and WOULD work.
bump to late 54 and that gets you a 6-7-8-900 series.. and they FOR SURE will work.
what's 2 years?
soundguy
   / Need a Ford
So in your opinion I should be looking for???? Thanks:)
   / Need a Ford #6
from my first post:
soundguy
   / Need a Ford #7
in the prev post, the first 2 are my 63 4000 rowcrop with factory wide front with a 4 spd and combo sherman hi low tranny.. making it 12 forward gears and 3 reverse..
the last one is my 950 'essentially' the same chassie of the other rowcrop save the front pedistal..e tc. showing you a narrow front option. VERY NIMBLE.. that one has the 5spd tranny... same essential machine as a 7xx or 2000 rowcrop 4 cyl... except for the smaller 134ci engine..e tc..
these next pics show my 63 2000.. same essential chassie of a 6xx and similar to an 8xx, but without the hp. just showing you the difference in height. which may help you decide between an ag and a rowcrop for mowing..e tc..
soundguy
   / Need a Ford #8
i would find a 4000 with 5 speed or maybe a little newer 2000/3000 with 8 speed
   / Need a Ford #9
i was going to suggest a 3 cyl as well.. but it appears he want's to stay as 'old' as possible.
though for sure that 8spd would be nicer for gear options..
soundguy
   / Need a Ford #10
What would be wrong with the 8n/9n and stepping down to a 5' cutter??
SKID STEER GRAPPLE (A53843)
SKID STEER GRAPPLE...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
