Need a finish for my trailer deck.
/ Need a finish for my trailer deck. #1
Rebeldad1
Veteran Member
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
Trailer is a couple years old and the trailer deck needs some protection from the weather.
What do you use to protect the wood surface from the weather but not leave a slippery painted top cote?
Thanks in advance!!
/ Need a finish for my trailer deck. #2
Whatever U use as a finish U can always sprinkle dry sand B4 the finish dries and that'll take care of the slipping aspect.
Were it me (and that is how I treat my wooden bed) I applied, liberally, a wood preservative from time to time.
Commercially I think operators simply rely on spilled oils to act as their preservatives.
/ Need a finish for my trailer deck. #3
I've been told coal tar extract driveway sealer is used to protect floors of semi-trailers. You'd want to sprinkle some silica before it dries, and of course, expect the silica to flake off with abrasion. I use used motor oil - but that's not going to give you a non-slippery surface
/ Need a finish for my trailer deck. #4
I have been using Tompson Water Seal on my wood decks but find that although water still beads on it, the wood still gets weathered looking in the sun.
A few people have told me to use linseed oil and that it is much better.
/ Need a finish for my trailer deck. #5
Same here, mines only a 4 x 8 trailer so I've no need to walk on it. I use it on the plywood floor and decking sides. !2 years old and not a bit of rot anywhere........Mike
/ Need a finish for my trailer deck. #6
We used a good deck preservative. Thompson makes a few varities and we tried there best, most expensive one. Its worked for a few years. I'd suggest any good quality deck stain with some color/stain in it.
/ Need a finish for my trailer deck. #7
I use boiled linseed oil......because that's what the manufacturer recommended when new. I'm on the third deck in 22 years. Hauling gravel on the first two decks probably hastened the rot. Now, I don't haul gravel anymore and this deck should last "forever" LOL
Linseed oil brushes on easily and is non slip when dry. I try to put a coat on every year or so....My trailer is a 12 ft industrial skid steer hauler....just used occasionally by an old man.
Cheers,
Mike
/ Need a finish for my trailer deck. #8
I also use boiled linseed oil on my PJ 20'er. It sits outside under pine trees when not in use. I re-coat it using a roller about every 3-4 years and have no signs of deterioration at all. Be aware though, the linseed oil will turn dark, near black in short order, if the color is a problem for you.
I've found that Thomson's sealer dries out too quickly especially if out in the sun. I do like Thompson's, but not for my trailer floor.
/ Need a finish for my trailer deck. #9
I'd imagine that those of us that are occasional users versus those that use their trailers almost daily have different needs for maintenance. Those that are are running equipment on/off with muddy/dirty tires/tracks probably see used oil etc as a good option.
/ Need a finish for my trailer deck. #10
I am considering saw mill cypress for the tilt trailer. The pressure treated pine can be very slick when trying to load an empty tractor. Loading heading down hill solves that issue but I prefer loading on a flat place.
/ Need a finish for my trailer deck. #11
Thanks in advance!!
Absolute best way to "protect the wood surface from the weather" is to store the trailer inside!
/ Need a finish for my trailer deck. #12
Yes, but the treatment does wear off and be less slippery. You can also get rough treated lumber, but it will be thicker and might not fit.
Speaking of linseed oil. My folks thought regular preservative house stain was to expensive, so they used linseed oil on there house. In one word, worthless.
/ Need a finish for my trailer deck. #13
When I was in high school I built a loading shute out of sawmill Cypress I believe it was 12 ft so the angle was low enough we never did put cross pieces on it for for cattle traction because they got enough friction.
/ Need a finish for my trailer deck. #14
I'm thinking of trying this (but my deck doesn't need re-sealed until the spring):
I may also consider this one that lots of people use on docks:
/ Need a finish for my trailer deck. #15
I will second boiled linseed oil. It last longer than Thompson's water seal or any common furniture wood preservative (Polyurethane, etc) and actually preserves the wood.
/ Need a finish for my trailer deck. #16
I had a cypress front porch, tongue and groove and sealed. It did not last 5 years before it was rotted in many spots. Went to TREX or something similar and happy with that. Don't think it would hold weight on a trailer though.
/ Need a finish for my trailer deck. #17
Thompson water seal makes a variety of products. The low cost ones aren't much more than paint thinner. You need to use something made for outdoors, like a deck sealer.
/ Need a finish for my trailer deck. #18
Cabot makes good deck sealers, but maybe a bit expensive for trailer decks.
JOHN DEERE 5100M TRACTOR (A63291)
JOHN DEERE 5100M...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2016 INTERNATIONAL PROSTAR+ 122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
Caterpillar 950F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 950F...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
UNUSED WOLVERINE HYD MINI STUMP GRAPPLE (A64281)
UNUSED WOLVERINE...
