Need a box blade
   / Need a box blade #1
blaux61
Ohio
MF20
I have a 1974 mf20 industrial with the Perkins diesel. Was wondering what size box blade you all would recommend for that size tractor. I will be using it primarily to spread top soil but will occasionally want to use the teeth to tear up the ground. Was wanting to run a 6' blade if I could.
   / Need a box blade #2
I think you will be fine with that 6 footer. I use a 6' with my Massey Ferguson 230 which has less power (38hp).
   / Need a box blade #3
Tractordata lists your machine at 77.5" wide, so you need a 7' to cover your tracks. Lists at 42 HP with Perkins, so should pull the 7 footer, and you have plenty of weight for traction.
   / Need a box blade
Thanks for the info. I think running a 7' blade would be optimal.
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
