need a 130 farmall eng.
   / need a 130 farmall eng. #1
farmall 55a case
case ih farmall 55a
My grandpas 130 got water in it over the winter! I took the cylinder head off and the number 3 cylinder intake valve was in the open position? The number two and three cylinder was full of coolant. The exhaust manifold was full of water and the oil breather also! When I drained the eng oil it was all coolant. Do any of you guys think it just the cylinder head or do you think it cracked the block also? Any input would be awesome! And where should I be looking for cracks at on the block? Thanks!
Oh its s farmall 130
   / need a 130 farmall eng. #3
static coolant pressure test it with the pan off. Harbor freight has the kit for cheap.
Take the oil pan off? And put the cylinder head back on?
   / need a 130 farmall eng. #5
It may have just cracked a sleeve, and let the coolant into the oil pan.
That would be a C-123 engine. If the block cracked, you should notice a horizontal crack mid-way down the side, I'm thinking ususlly on the carb. side. Or, between the cylinder liners, on top of the block. If in doubt, you can always take it to a decent engine shop that can magnaflux the block, and check for cracks.
Being it had coolant in it, but water got in the exhaust, and on into the #3 cylinder, it's more than likely a cracked sleeve. If you polish ( steel wool or something similar, if not too bad) the inside of the #3 cylinder, look for a dark hairline streak, running verticle.
Ok thanks even tho there was still coolant on top of the pistons it could still be crack?
   / need a 130 farmall eng. #7
*YES!*
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52705)
2014 CATERPILLAR...
2021 Chevrolet Corvette Stingray C8 LT1 Convertible (A51694)
2021 Chevrolet...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
2025 K3325 UNUSED Double Garage Steel Barn (A53117)
2025 K3325 UNUSED...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
