rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 11,400
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
LOL .... it looks like it - meaning that it looks like considerable care, time and effort was given to achieving an aesthetic result - it's a work of art ....Took me almost two weeks to build, including puting in the grass seed. Most of the time moving the rocks here and there, over and over..
I'm not sure if I'll have the patience, time or energy to achieve as good a result ....
Yup, same here .... I imagine it will be a lot of "puzzle-solving" ....It would have been easier if the rocks were more uniform, but had to work with what I had.
I'm hoping that sorting and grading the rocks will allow me to avoid moving the rocks repeatedly .... at least with the bigger ones ....
If I had to guess, I imagine that I have something on the order of 75 to 125 rocks/boulders that are way too large/heavy to be moved by hand .... and maybe another 150 or so that I could move by hand, but are potential nut-busters ....
I've already managed to trip and fall into the bucket edge on the loader while trying to chuck one of the latter into the bucket .... ain't looking to repeat that experience ....
Yeah .... the "soil" I will be working with is pretty undisturbed .... in some places it looks like it's well on its way to becoming rock ....I dug down and removed the sod about four to six inches, making sure not to disturb any soil I did not have to. With some of the larger rocks I dug a little deeper. The main thing is to keep the soil compacted so the wall will settle as little as possible, but it will settle over time.
I think for me, the way to avoid excess settling is to ensure that there is little water lying or retained at the base course of stone - fill in around the stones with clay or loam and then slope away from the base to move the water away.
That's one of the differences - you had to add soil and fill in behind it - and I removed soil to create the cut - probably something on the order of 5 to 10 yards ....Everything is leaned back into the bank, and I packed the dirt pretty good behind the rocks [ tamped with a big steel tamper ] as I built the layers. Don't look like much of a wall, but it took about 10 yards of dirt to fill in behind it. I folded all the extra fabric back in behind in spots.
My "fill" is mostly already there .... the only thing I'll be adding is 4" to 8" of topsoil - on top of the clay and sandy loam that's already there.
Of course, some of that may fall into whatever voids exist behind the wall, between the wall and the undisturbed soil - unless I fill in with some washed 57 gravel (might be better for drainage ....)
The other thing I might do is run the (porous) non-woven up behind the rocks to contain the clay/sandy loam behind the wall .... and then place some woven (from an old pool cover) or solid 6 mil poly at the top, under the topsoil - to prevent the topsoil from falling in and working it's way down behind the wall.
LOL .... keep 'em busy .... so they're not chewing on something more critical .... :thumbsup:Give the chipmunks more to chew thru.....![]()
Thanks for the input and info !
